Leaking bottom radiator seal
Discussion in 'Ask An Owner Operator' started by Sktrucker89, Sep 11, 2016.
  1. Sktrucker89
    Sktrucker89 Bobtail Member
    32
    Mar 9, 2016
    I have a 2013 cascadia. My radiator started leaking from bottom . Got pressure tested and found our it's bottom plastic plate seal is gone. Is there any temporary patch up fix to stop coolant dripping that I can do to make it back to my hometown through cvsa brake check week .where I have it booked for changing the rad. Thanks in advance for your replies.
  3. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    i'd just say good old fashion radiator sealer, i think Bar's?
    Sktrucker89 Thanks this.
  4. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Let me just say the Cascadia radiator vendor has been very busy since it's inception....mounting a radiator solid between the frame is an invite for twisting the living daylights out of it and they all leak eventually. I've replaced them as low as 30k miles. My advice is NOT to put any leak-stop in and get it replaced....the coolant passages in these newer engines are under enormous load to keep things flowing/cool that if the leak-stop were to restrict or block them you're asking for trouble.
    mitmaks and Sktrucker89 Thank this.
  5. tony97905
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    BTW, if you got a friend to help you it only takes a little time to replace one by pulling the bumper (8 bolts), hood (3 bolts) and removing the radiator straight out the front....switch over coolant tank (top bolt notoriously seizes in the metal insert and just spins in the plastic) and reverse procedure.
  6. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    It's a common problem in the lower right corner. Mine got replaced also while i was driving that same year truck. And you won't make it another 100 miles. when that baby starts. It wastes no time in going from bad to extremely bad.
  7. Sktrucker89
    32
    Mar 9, 2016
    Well I made 2300 miles n getting it replaced . But thanKS for fuelling negativity .
  8. Sktrucker89
    32
    Mar 9, 2016
    Which rad manufactuter suited you better ?
  9. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I find that any bolt I have a wrench on seems to be notoriously seized.:mad:
    clausland Thanks this.
  10. snowwy
    20,525
    13,261
    Jul 6, 2009
    Just saying. Mine went literally in a matter of 100 miles. From unload to getting in to a shop. 15 gallons i threw in.
  11. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    I'd fix it pronto....Forget dumping sealer (gunk) in the radiator... You'll be asking for trouble down the line.
