Leaking Air Line into Air Tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bill43452, Jul 8, 2012.
  1. Bill43452
    Bill43452 Bobtail Member
    34
    2007 International 9400I, The air line going into the tank is leaking at the fitting and it has no nut or anything to tighten this up. is there an o ring in there or does anyone know how to tighten this. it is just a round brass fitting and I don't know how this comes apart. Thanks!!
  3. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Look closer. Its a flare fit quick connect. There is a small ring that you push towards the tank then you can pull the line out. This ring has like a little jaw. Picture a Chinese finger trap. That fitting works the same way. Once the line is off, cut the end and make sure end is flat. You want it even, then push it back in. it should take care of your leak.
    Bill43452 Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    i like the way you explained that (chinese finger trap) i hate those fittings everytime i have one leaking i replace with a feral and nut style.
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Those forever failing fittings are used to speed truck assembly time on the line, and the end user gets to pay the high cost for them. I don't use them unless there's a clearance problem otherwise.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Just as bender and superhauler said:
    Get rid of those pushlock fittings. They are quick and easy but are a leak waiting to happen.
  7. Bill43452
    34
    i appreciate the help i did what you suggested and it worked and stopped the leak. I would like to switch to the other fittings but i seen the snap rings that holds those in there are the holes threaded or do i have to replace the whole tank? Thanks again!
  8. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    the fitting should just be threaded in the tank. unless it's something brand new they have came out with.
  9. Bill43452
    34
    there are snap rings at the beginning of the hole around the fitting
  10. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    You pop the snap rings and replace with same fitting. That's the new tank design by Hendrickson used on the 2007 to 2010 internationals. 2011 they changed to the Meritor tanks with thread fittings because the Hendrickson design has too many problems.
  11. Dana W
    Dana W Bobtail Member
    I have a 2006 and having the same problems. It's not the line leaking, but looks to be the actual fitting itself. Got the snap rings out, but how do I get the fittings out? Just pull out or are they threaded. Just didn't want to tear anything up and end up costing more.
