late model 2012 Kenworth T700 driver's side door picking up air...
Discussion in 'Kenworth Forum' started by ShadowCat, Mar 7, 2014.
  1. ShadowCat
    ShadowCat Bobtail Member
    34
    8
    Dec 10, 2013
    Hampton Roads, VA
    My husband doesn't yet have the ability to internet :) so I'm posting for him.
    He has a late 2012 T-700 and he has noticed that the driver's side door seems to have a gap which is letting in outside air, making it very loud in the cab. It has been doing this today but not before.
    He has had no accidents, no wind whipping the door open, nothing that would have contributed to such a thing. From the outside, the door is flush with the truck.
    Anyone have this problem? Anyone know a good fix for it? He just started driving about a month ago and doesn't have much in his maintenance fund, so a cheap fix would be ideal if it exists.
    Thanks.
  3. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Check the weather stripping around the door. Compare it to the passenger door.
    ShadowCat Thanks this.
  4. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    lets see another happy Trans Am Leasee
    I found on windy days sometimes the door leaked air
    sometimes it was ok
    it can be adjusted but as you say cost money
    if it leaks air enough to whistle lower the window an inch will stop that
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    Two months ago you were seeking advice on how to pass the backing portion on a cdl test. Today you mention a maintenance fund. I sure hope that is a walk away lease and you two are smart enough to walk away before you are facing financial ruin. My heart wishes you the best of luck and success, the part of me grounded in reality knows you have practically no chance. The deck is stacked and the dealer cheats.
  6. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    The T700 is really just a glorified T2000, I have had over 20 of them over the years, It should take less than a hour to fix it if he has any mechanical ability at all.
    The problem is the door is fiberglass and does have some give to it, the factory never seems to be able to align them properly, and dealers are not any better.
    If they haven't changed anything he will need a Phillips and Flat screwdriver and a couple of TORX bit, I am sorry but don't remember the size.
    First raise the hood full open, there will be a "collar" made of fiberglass(plastic) that starts at the front of the cowl area and runs vertical down to where it meets the tire, it then takes a 90 degree turn and goes along the bottom of the cab to the back of the door opening.
    Remove all of the screws holding that in place and carefully remove that cover from the side of the cab, this will expose all of your adjustment screws for your door hinges.
    You can now adjust the door in an infinite amount of ways, in, out, tilt, angle, you also have a big TORX screw on the cab upright where you door clasps the lock post, loosen that up and shove it all the way in, (DO NOT TAKE IT OFF!).
    Adjust your door so you get a nice even squish around the whole seal, the top of the door frame being the most important, usually you don't have to move them a lot. Make sure the door sits square in the cab opening and flush or just slightly "in".
    THEN when you are happy with the way the door shuts and seals, adjust your big TORX door post so that the door has a good solid feel when you close it. The door post should NOT lift the door up or down, that adjustment is solely in your hinges, that post is ONLY a depth adjustment for the back of the door.
    You do NOT have to slam the door if it is adjusted properly, you should be able to push it closed with two fingers. Problem is most people really don't know how to close a door, as dumb as that sounds.
    Because that is such a large cab it does/should have two air flap releases at the back of the cab, they are there so that when people slam that door the air inside the cab has somewhere to go, in all honesty, you should just crack your window and inch or two and your door will close much easier.
    But most drivers would just rather just sit there and slam the #### out of the door, that is how you get broken hinges.
    Sorry to rant, but it is a pet peeve of mine, I have pulled more than one of my drivers out of the cab of a new truck for sitting there slamming the door.
    Hope this helps,
    Stan
    Alleghenymike and ShadowCat Thank this.
  7. ShadowCat
    34
    8
    Dec 10, 2013
    Hampton Roads, VA
    It is a walk away lease, but we have plans for the future that require having a truck and not working as a company man. If things do get too bad, he can walk away at any time.
    By the way, he passed the test with the highest scores from his school. :)
  8. ShadowCat
    34
    8
    Dec 10, 2013
    Hampton Roads, VA
    Wouldn't lowering the window cause just as much noise, thereby not relieving the annoyance of it being so loud he can't hear me? I've not been in a big rig, so I honestly am wondering.
  9. KANSAS TRANSIT
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    You will get a bit of wind noise when cracking the window (depending on which way the wind is blowing and the velocity) while driving, BUT, you might not get the whistle/roar that you get with the door pulling away from the seal.
  10. ShadowCat
    34
    8
    Dec 10, 2013
    Hampton Roads, VA
    I *think* we have a fix...will let you all know, thanks for the suggestions. :)
  11. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Not being able to hear your passenger talking could possible go in the plus column.
    HoneyBadger67 Thanks this.
