KW W900 OEM Dual PSI Gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Sep 18, 2010.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    On my dual FRONT/REAR PSI gauge, I removed it and re-installed it but neither fitting is labeled.
    I think the TOP fitting is ORN and the BOTTOM fitting is GREEN.
    (as it is installed into the dash)
    Can anyone confirm that??
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    hmmm seems to be a good point for a sharpy in your pocket
    if you start your truck--which ever hose air comes out of first--that will be wet tank---then put that to one fitting and see what needle moves--you want wet tank to be on the orange needle---thats easiest way i can think of
  4. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    primary air is green. Secondary air is orange. Thats all I know. I think ORN was on top and GREEN was on the bottom of gauge. I have tons of photos of the dash but not THIS part it seems...
    I just pulled on the bleed cord on the wet/primary tank and the green/front arrow dropped.
    So I have them hooked up right.
    I disconnected them to install a digital TelTek dual air gauge. Problem is it won't fit into -that- opening.
    It will fit into others but then none of the other gauges will fit into there. So I would need to put a blank
    in that spot and give up a gauge. Stupid...I will call TelTek on Monday and see what the deal is.
    They are awesome to deal with (directly) and have no issues taking anything back....
    I got an OOIDA discount on the gauge ($225) and I like the idea of dual/digital readouts but not if it doesnt
    fit...My current gauge is hard to see at night, even with new bulbs...
  5. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    sorry bout that--was second guessing myself on the clours as well
