I'm keeping an eye out for a junk truck to rebuild for work in the 1955-'75 range. I don't really care what shape it's in as long as it's got a steel frame and 3 axles. A cab would be nice. I figure I can rebuild anything, but I'm wondering, what are the dimensions of the hood on those narrow nose trucks? Would a Cat 3406,or 855 cummins, or something in that size range fit? Also I thought they discontinued the narrow hood KWs in '69, but I heard somewhere that they kept on making 'em until '82 when they went over to the w900b. Can anybody verify this?![]()
KW narrow nose with a big engine
Discussion in 'Kenworth Forum' started by Captain Mudsocks, Sep 22, 2019.
Page 1 of 5
Maybe @Ridgeline can help a fellow Michigan driver.
Captain Mudsocks Thanks this. -
I know you could still get a narrow nose A model up into the 70's at least, and yes a 3406 or any 855 cummins were used in them. I have my eye on one, a 71, that came with a cummins, still has one, but aluminum frame and it is cracked.
I am wondering if a there is enough room to fit a 12,7 detroit and the air to air, or a 3406 E and have enough radiator capacity to cool some higher horsepower.Captain Mudsocks Thanks this. -
Bean Jr. Thanks this.
I know the engine itself will fit, where I am concerned is stuffing the air to air, plus the ac condensor behind the grill on a short hood, and cooling capacity on the skinny radiator.
The A models originally used a the grill densor for the ac, and I know you can get an air to air ib the wide hoods with some modifications,, for sure if you still use one, but they are not the best, especially since we had the freon change.
I actually know of at least one thin hood, actually butterfly extended hood that has a v8 cat under it, just a beautiful truck in every way.Captain Mudsocks Thanks this. -
@AModelCat likes those old trucks.
Captain Mudsocks and AModelCat Thank this. -
Big motors are over rated
Page 1 of 5
