Found this site while searching to upgrade the headlights on my 2007 T800.
www.slclighting.com
Wondering if anyone has ever dealt with these guys, and if so any comments?
Also wondering if there is a low beam bulb available for this system, (comes with the #9007), that is slightly less bright.
While I want more light up front, I am also one of many that get aggravated with drivers using the "too bright" low beams.
Hope the link I posted can be opened, kinda ignorant about this.
They emailed some photos of the lightbox back, it has a plastic strap holding the cup behind the bulb- unhook the strap, remove the cup, and the bulb is easily accessible. Seems like a nice setup. SLC Lighting advised of a KW engineered voltage protection glitch that may/may not cause the high beams to turn off, (low beams are not affected), and recommend a relay to prevent the cut off.
KW headlight up grade
Discussion in 'Trucks [ Eighteen Wheelers ]' started by droy, Dec 14, 2013.
Page 1 of 3
http://www.slclighting.com
Made it hot fer ya.droy Thanks this. -
I got mine here...
http://www.bigrigchromeshop.com/Merchant2/merchant.mvc?page=BRCS/PROD/HDLITB/GGCRYSTPKG
Made specifically for the KW/Freightliner "in fender" composite headlight bucket.droy Thanks this. -
so it does come with all 4 headlight assemblies minus the bulbs? what bulbs did you go with for bright and dim. ive been looking for a better set up on my kenworth. this seems like one of the better deals i have seen for the money. -
+1 on the KW speaker lights.
Cant beat them. -
So many pros to these lights, compared to regular halogen or even hid. -
SLC Lighting is an authorized distributor for KD Lamp Co., which was the original equipment manufacturer of the KW headlights. These would be a direct replacement.
with the jw lights how did you guys get them to fit in the housing? with the pigtail and connector they hit on the back of the housing and I threw it together like that although it was squishing the light and bezels. I'm thinking the only thing I can do is cut the wires in between the light and connector and extend them some to get the connector to the dead space between the high and low lights.
Not sure ire what your exsperaincing there, but those jw speaker lights are a straight up swap in the regular 4 headlight system that comes standard in kW t800 and westernstars ECT......).
I never had any issues. Plug @ play.
Page 1 of 3
