Needing a part number Napa, TRP, …….. for an old KW 8 bag system. Number on the bag is K-303-15.
KW 8 bag air bag replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Oct 10, 2023.
You may need new air lines also.The fittings on the steel tubes connecting the bags almost always leak when reused.
mile marker 27 Thanks this. -
If replacing 1, replace all, its more expensive, more work, but when one fails, the rest are on their way out too
Rubber duck kw and Bean Jr. Thank this.
A pair of vise gripes in the appropriate spot will keep you rolling.
Just pinch off the air supply going to the blown out bag,one of the plastic lines,then duct tape to keep the vise grip from coming off.We do it all the time hauling gravel,best to not load it quite as heavy as you normally would.
They make quick connect caps now. 20 for $15 on Amazon. Great for brake cans and air bags that fail. The days of bend and pinch with vice grips are over. I work parts at a TA Stop. Just found this discussion group. Air Bags change out quick when you can find one. We have some still on back order 3 months ago. there are some weeks we will replace over 30 airbags.
mile marker 27 and North Pole Nightmare Thank this.
