KR Scanguage or Scanguage II ( which way do you go )
Discussion in 'Ask An Owner Operator' started by US MARINE, Jul 31, 2013.
  1. US MARINE
    US MARINE Heavy Load Member
    823
    170
    Sep 15, 2011
    Just wondering pros vs cons of each and is the KR version worth the extra 30.00 ? Do they both have a universal plug or is that just the KR branded one etc ..
    Thanks
  3. SamTheMan
    SamTheMan Light Load Member
    155
    69
    Jun 20, 2013
    For 30 bucks more you can say you gave to a snake oil salesman.
    Rawze Thanks this.
  4. Horse Whisperer
    Horse Whisperer Light Load Member
    199
    180
    Jan 6, 2013
    I got mine from Ebay... it's the Scangauge D and has two different dataport plugs (it's a 2-sided plug, one side hits the 9 pin, the other hits a 6 pin dataport)... To be honest, from the descriptions I've heard (and this is STRICTLY based on what I assume is incomplete information, so don't go nuts on me if I'm wrong), there's not much difference between the 2 versions other than a few extra (possible) gauges in the KR version that, I believe, can be obtained from the manufacturer for free if you pull a PID report from the device (the instructions tell you how to do that)...I'm perfectly happy with mine as is, but I may send the PID info at some later date.... hope that helps to muddy the pool a bit!
  5. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    I have a Scangauge KR for sale w/ window mount if your interested.
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    dang. someone didn't like there gauge
  7. Colorato
    1,336
    865
    Feb 22, 2011
    Actually I think it's cool. Works good. Just not my thing.
  8. US MARINE
    823
    170
    Sep 15, 2011
    be honest why you dumping it ? Is it junk or you just personally don't like
  9. Colorato
    1,336
    865
    Feb 22, 2011
    It's not mine. I got it for a friend at Louisville show off KR. He got out of driving and I drive a company truck so not much use to me.
    If I drove for a company with a fuel bonus I'd use it.
    US MARINE Thanks this.
  10. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    Ill be honest I really don't care for mine the boost gauge only goes to 32lbs next problem I have is it only has a 48" cord or so in my Freightliner my port is behind the driver seat at the door so by the time you run it the thing only makes it to the bottom of the dash and can't just look at it because its behind the wheel and down low. The next problem is my door panel hits it when you shut the door I pulling my port and is just laying there now. I've had mine over a year and still can't figure out how to read codes or all that other stuff you can do with them, ya it was cool when I first got it but now the new is wore off and don't look at it much at all.
    The only reason I got mine was it was cheaper than buying gauges.
  11. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    The KR version has software modifications that make it more useful in a class 8 truck. The readings are buffered using a 8-second sliding average of the values you are displaying. What that does for you is the readings jump around less, and make the gage more useful.
    Snake oil? Hardly, it displays the current operating parameters out of your truck's ECM so you can fine tune your driving style. If all you do is push the throttle to the floor or slam on the brakes, you won't need one. I find it's rather useful.
    TallJoe Thanks this.
