Kit Master 9500 HP
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Diesel Dave, Jun 2, 2019.
  1. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    I have to get my Horton fan clutch redone. Peterbilt recommendation was to use the Kit Master 9500 HP for my application. Said it had less parts and similar to redo. Problem was they didn’t have it in stock so I went with the genuine Horton kit which was a few dollars more, and felt more comfortable going genuine. Opinions are welcomed, that’s why I started this thread.
    Oxbow and T800H Thank this.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    In my experience, Kit Masters is a good product and their rebuild kit outlasts original Horton.
    snowman_w900, Cat sdp, Oxbow and 2 others Thank this.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    I scrapped the Horton when the bearings went out and the fan started wobbling so hard it trashed my water pump. Put a viscous fan hub on there...lighter, simpler, and significantly cheaper. Been several years and no issues. I don't know why they like to over-engineer things like that when all we need is something simple that works.
    Diesel Dave and T800H Thank this.
  5. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    Can you post brand or maybe even part number?
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    We use a good bit of Kit Master products. Great stuff and they have a nice website and super great live customer service.
    snowman_w900 and Oxbow Thank this.
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    No. All I can tell you is that I got it from Mack, it bolted onto the water pump, and the fan bolted to it.
    Oxbow Thanks this.
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I was wondering what kind of motor you had that the fan could trash the water pump. That viscous clutch may work fine for your mack, but I would not want it on any cummins or cat, unless were talking a pickup engine.
  9. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Why not? It's a much simpler design...less moving parts...less to go wrong.
    When the bearings in the horton fan clutch went out, the fan picked up a nasty wobble. The wobble is what took out the water pump. I started smelling antifreeze going down the road, pulled into a Walmart and popped the hood. Saw the fan wobbling and the water pump leaking. Pulled the fan off and topped off the system with water and it got me home. With the trouble-free operation of the viscous fan hub, I'd never spec a truck with a horton.
  10. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I am guessing you have never had a Mack MP motor with electronic viscous fan clutch?
    snowman_w900 Thanks this.
  11. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    If your driving that red 379?
    I would have looked into the old Kysor fan clutch they are easy to adjust.
    But never tried doing it my self.
    Diesel Dave Thanks this.
