kingpin
Discussion in 'Questions From New Drivers' started by Freebird135, May 19, 2009.
  1. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    might sound like a stupid question, but is it possible for a kingpin to break off? does this ever happen?
    i know they arethick and very strong, but a trailer is also very heavy, and they do get jerked by rough shifting
    anyone ever heard of this happen? just something im curious about
  3. doubledragon5
    doubledragon5 Road Train Member
    2,935
    4,088
    Jun 8, 2008
    Lewisville TX
    Yes it doesn and has happened..
  4. PAJ1979
    PAJ1979 Light Load Member
    55
    11
    Mar 28, 2009
    Southern Illinois
    It happens rarely in bad crashes, but I've seen more fifthwheels ripped off the frame of the truck than I have broken kingpins, its a pretty tough lil bugger.
  5. Freebird135
    1,527
    906
    May 7, 2009
    wow
    how come dollys have safety chains, are they more likely to come off while moving or what? thats somethin else i wonder about
  6. PAJ1979
    55
    11
    Mar 28, 2009
    Southern Illinois
    I've never dealt with dollys, but I assume they have to have safety chains because they probably fall under the same laws as any other bumper pull trailer.
  7. Freebird135
    1,527
    906
    May 7, 2009
    i see
    i think it is a law tha all utility trailers and camper trailers have to have safety chains
    ive actually had a utility trailer come off the ball before...the cotter pin that keeps the coupler locked over the ball fell out
    the safety chains held it, but they got wedged into the holes by the force and i had to hammer them out
    that was a fun day
  8. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    One of the main reasons dolleys have safety chains is because of the pintle hitch they use to hook to the front trailer or vehicle. Think about all the force on that pintle hitch with the weight of the dolley, trailer, and load then figure in the movement forces. You can see why safety chains are required. The pintle hitches break more often than the kingpins. The pintle hitches are cast iron or steel where as the king pins usually start out of solid bar stock and are machined to spec then heat treated to increase the hardness. I have personally seen a king pin break from a guy backing into it very hard, but I have a feeling he had hit it hard many times before.
    Freebird135 Thanks this.
  9. Freebird135
    1,527
    906
    May 7, 2009
    cool thanks for the reply
    i see drivers backing into trailers to hard all the time....i have done it but not intentionally, only in the snow when u have to really give it some gas just to get under the #### trailer...the wheels spin, then catch and you back into the kingpin too hard
    they refuse to plow or even salt our lot no matter how bad it is
  10. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,225
    44,135
    Jul 23, 2007
    Midwest
    The boat did this to me when I was crossing the tracks. Sceered the crap outta me. :biggrin_2554: LOL We immediately replaced the tongue on the trailer after that fun ride, and yeah the chains did their job, thank god, because there were people behind me. :biggrin_2552:
  11. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Ive never seen a kingpin break off but have seen cracks around them which would have resulted in a break. Most times they are hard to see because of all the grease on the plate.
    You all do know, that when hooking up your safety chains to your utility trailer or boat, to make sure they are long enough so you can cross them under the tongue that way if something fails, the chains will cradle the tongue (if its still there).?
