Kingpin setting vs axle weight
Discussion in 'Ask An Owner Operator' started by Cat sdp, Jul 6, 2016.
  1. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I've never understood this....
    If you have 2 identical units and loads and one trailer has a 18" kingpin the other has a 36" will there be a differance in axle weight...?
    I love the 18" for tank/dump work. But the vans seem to like the deep pins .....
  3. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,918
    Dec 12, 2015
    I'm sure someone has a better answer, but you won't be able to get as much weight on your steer axle. Or, it's harder to do so.
  4. Blackshack46
    Blackshack46 Road Train Member
    The farther you are under a trailer the more weight on your tractor all around. At 18" two pallets would barely be over the drives, so less weight. At 36" you'll have most of the front to pallets on your drives so more weight on the drives. More on the drives also increases the weight on the steer axle.
  5. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    I'm no expert on heavy load,but I seem to remember king pin setting "not making much difference" like maybe 3 or 4 hundred lbs. Max.When I hauled heavy loads of flour,I typically ran the tandems in the 8th hole,starting back from the doors and had no pallets loaded in the "last skid space" by the doors.Ran kingpin where I could pull the pin between the tires/axles.Never had to readjust at the Cat scale.
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,701
    Mar 30, 2014
    You can't adjust the kingpin setting. It is where it is on the trailer. Vans usually have it around 36" from the front of the trailer. 20' container chassis are about fifth wheel deep.
    BUMBACLADWAR Thanks this.
  7. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    I assumed he was talking about his fifth wheel plate,not the actual kingpin
  8. Dustyroads38
    Dustyroads38 Light Load Member
    80
    77
    Dec 23, 2015
    Vernal utah
    Close, but the weight on your drives doesn't transfer to your steers unless your Fifth Wheel is forward from the exact center of your drives.
  9. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    True,but given enough wiggle room on weight and tandems back,and no pallets in the last 4 feet,I preferred not to run borderline on the steers.Drives not as concerned.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
  11. MACK E-6
    48,136
    219,708
    Yes indeedy.
    More kingpin setback means the nose of the trailer is heavier.
