Kingpin Locks
Discussion in 'Questions From New Drivers' started by JC1971, Oct 5, 2013.
  1. JC1971
    JC1971 Road Train Member
    2,607
    9,296
    Jul 29, 2013
    L.A.
    Does anybody use a kingpin lock in truck stops? To me that would just alert somebody that you might be carrying a high value load.
  3. Bram
    Bram Light Load Member
    133
    66
    Dec 9, 2011
    Gurnee, IL
    I always use one if I drop a trailer, empty or not. Our company had an empty stolen but all turned out well when the thieves brought it back filled with used tires. It's also our company policy. So should something happen to one I dropped without a lock it would cause me to lose my job.
    Saddletramp1200 Thanks this.
  4. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I would be more inclined to believe you would stay hooked to a high value load and a kingpin lock just suggests you don't want anyone to take your trailer. Of course I pull a stepdeck and only drop when I'm empty, so it's no mystery why mine has a kingpin lock on anyways, lol.
    CondoCruiser Thanks this.
  5. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    When I worked for Schneider their policy was if you were going to be away from the truck for more than 10 minutes you were to drop the trailer, lock it and then bac the tractor in front if the trailer. I never did though.
  6. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    So how does that work when you back into a slot between two other tractor/trailers and go in to eat/shower?
  7. HotH2o
    4,098
    4,865
    Sep 23, 2012
    Not sure. Like I said I never locked the kingpin. Haha. If a good movie was on in the drivers lounge I'd sit there and watch it.
  8. fr8te_sh8ker
    fr8te_sh8ker Medium Load Member
    497
    395
    Jul 8, 2013
    Just the opposite, as I don't unhook when loaded at a truck stop. Stay with your load.
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I think a kingpin lock would be the hardest of the three to bypass/remove.
    Am I correct?
    Mikeeee
  10. NCT_PA
    NCT_PA Light Load Member
    58
    38
    Jan 16, 2011
    Chambersburg, PA
    You are correct.
    Staying hooked is only a deterrent...and only slightly harder to get around than a glad hand lock...(witch can sometimes be unlocked with a simple fingernail file)
    If someone really wants a trailer that is hooked to a tractor, all they need to do is...
    1. simply pull the kingpin latch. If the driver didn't pull against the kingpin before setting the tractor brake it will release, then they can hook to the tractor and drag it out from under the trailer.
    2. back up against the front of the tractor and push it backward to relieve the pressure on the king pin, pull the pin and drag the tractor away from the trailer.
    The parking brakes on a tractor are usually only on one axle, so it can be pushed/pulled and those tires will slide....provided the spring brakes are even good enough to hold.
    One would also want to raise the trailer a bit to take weight off of the fifth wheel to make it easier to move the truck.
    Yes, this method would be noticeable and not quiet, but easier and less noticeable than trying to cut a kingpin lock off...provided it is a good one.
    There are different variations of kingpin locks.
    Some are just deterrents (slightly better than using a glad hand lock) while others are virtually indestructible.
  11. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    A kingpin lock is like a condom for your Wagon. These punks are smooth, I had the wheels taken off my Wagon @ the 76 in Indy. Wife & I were in the truck sleeping. To this day I don't know how they did it. The back row was all that was left when we got there.
