King pin won't take grease
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 24, 2020.
  1. mitmaks
    mitmaks Road Train Member
    2,597
    2,119
    May 16, 2014
    I was trying to grease top end of king pin but won't take grease. Took off zerk, grease flows through zerk but wont go through king pin
    truckdriver31 Thanks this.
  3. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    get wheel off ground. maybe a small amount of heat to center of king on the side pin to soften up hard grease
  4. mitmaks
    2,597
    2,119
    May 16, 2014
    Theres metal cover that zerk bolts onto. Can I unscrew it to check what's blocking grease from coming through or it will mess up something
  5. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    whens the last time you greased it. heat will soften up old grease. even like a plumber torch
    mitmaks Thanks this.
  6. mitmaks
    2,597
    2,119
    May 16, 2014
    I try to grease every 10k miles or less. Whenever I'm doing reset
  7. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    i would try the heat
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    You can take it off but it won't tell you much either likely. Don't keep trying to pump it in or you will force that cover off and then you have a real mess.
  9. SmallPackage
    5,960
    19,215
    Dec 20, 2019
    Marion Texas
    Jack both sides off of the ground and turn the wheel to the stop one direction. See if grease well go in. Grease everything on steering with wheels turned. Than turn all the way the opposite direction and grease everything again. Than center and grease again.
    This insures that grease gets all the way around the pins and balls on tie rods and the hard dirty crud gets flushed out.
  10. Goodysnap
    Goodysnap Road Train Member
    3,816
    9,304
    Jul 12, 2017
    If it wont take grease the damage has already begun. Since it's the top bushing unloading it back jacking will likely not do the trick but it wont hurt. Turning the wheel while greasing is your best option. Sometimes I'll take the grease whip off, blow it out and fill with PB or WD and see if that works through. If your using a hand grease gun, take it in the shop and try. The commercial air pump guns can generate more pressure.
    To make it right you may have to tear it down.
  11. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    speedco $34
