Kenworth T680 taillights not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GAShog19, Jan 5, 2023.
  1. GAShog19
    GAShog19 Bobtail Member
    39
    13
    Dec 28, 2022
    Englewood, Oh
    I have a 2019 Kenworth T680 where the taillights on the rear of the truck will not work as a running light - the brake lights both work - the turn signals both work - the 4 way flashers both work - they even flash in test mode - however they do not work with the headlights on or the marker lights on
    any ideas?
  3. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    Have you checked the fuses or relays? That would be the first place to look.
  4. GAShog19
    39
    13
    Dec 28, 2022
    Englewood, Oh
    i pulled the cover off the fuse box and read the labels but not finding one that read just taillights
  5. GAShog19
    39
    13
    Dec 28, 2022
    Englewood, Oh
    I found the one that said park lamp - it was a 10 amp fuse ... all I had was a 30 - I switched it out but still nothing
  6. Concorde
    Concorde Road Train Member
    4,347
    15,455
    Jun 29, 2016
    West Melbourne Florida
    Try new lights..worst case scenario is you’ll have two spares..
  7. Lyle H
    Lyle H Road Train Member
    1,289
    2,932
    Apr 16, 2014
    Get a test light and see if you have power for tail lights AT the taillight. You already know you have power there for brakes and turn signal.
    If you don’t, start working back from there.
    If you do have power, then you need new lights.
    RubyEagle Thanks this.
  8. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    Most likely you have a bad wire harness. My 2021 T680 did this same thing the first winter we had it, there were corroded wires within the sub harness for the taillights. Unless your really ambitious with it, consider letting the dealer mess with it, they'll have to order a sub-harness for it.
  9. GAShog19
    39
    13
    Dec 28, 2022
    Englewood, Oh
    so when I checked it with a volt meter I did not get 12 volts on the running light ... I only got like 9.4 - I was thinking it was because its a dimmer light than a brake light so that might be right - I put the new lights in and just by looking at it they still do not look like they are working ... but they are ... just very very dim - to the point you have to put your hands around the light to see them working
    any ideas
  10. Wendell76
    Wendell76 Bobtail Member
    I have a 2018 t680 with the same issue. Do anyone know the price of a subframe harness for the t680?
  11. GAShog19
    39
    13
    Dec 28, 2022
    Englewood, Oh
    I fixed mine ... unconventionally but it works ... I ran a wire from one of the marker lights on the front along the frame all the way to the rear of the truck ... figured out which was the running light and cut the wires and tied them to the line I ran from the front
