Kenworth t680 opinions?
Discussion in 'Ask An Owner Operator' started by Juanf94, Jan 26, 2023.
  1. Juanf94
    Juanf94 Bobtail Member
    5
    Looking into buying a kenworth t 680 with a paccar would like to know your experience driving one and mpg.
    Also looking at 2 options and would appreciate experienced o/o input
    1. Kenworth t680 2019 318k miles automatic $90k
    2 kenworth t680 2018 373k miles automatic $80k
    Are the 55k fewer miles worth the extra 10k or would I be better off getting the 80k and adding extended warranty?
  3. Siinman
    Siinman Road Train Member
    5,158
    12,909
    Mar 5, 2017
    Kansas City, MO.
    What are all the spec's on the trucks? Need all that information and what kind of duty cycle you are running. Then of course you will need to do all the checking or bring a mechanic that knows what they are looking at. Get a ECM dump as well on each truck. Either of them have an APU? If so they will have hopefully less idle time and that is a big issue with newer emission trucks.
    Juanf94 Thanks this.
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    813
    1,584
    Dec 15, 2021
    Not O/O but Halliburton had 5 t680's,automated,same years.
    They were day cabs,spec heavy,limited to 65 mph.
    We used them hauling cement.They ran well,65 mph loaded or empty.One of them had 200,000 miles on it,the others 50,000 to 100,000.
    7+ mpg,
    Never any major problems.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    Specs are EVERYTHING! buy the wrong spec for ur operation and you will end up paying MORE in fuel... Miles is just a Number my 1 Million mile truck has a lower maint cost then a 400k mile truck..
    Juanf94 and Siinman Thank this.
  6. seamutt
    seamutt Light Load Member
    115
    269
    Jun 15, 2021
    IMO opinion the Paccar MX-13 is a more reliable engine than the Cummins ISX-15, and likely slightly more reliable than the X-15. With notably better fuel economy than either of those two. As well, people seem to say that - since about 2017 - the Paccar's emission system problems have largely been dealt with as well. Where the Paccar does fall far behind, however, is in service. Especially so after an engine's warranty runs out. Peterbilt/Kenworth operate Paccar service like a secret cult, and you become almost totally dependent on them for life. Cummins engines, on the other hand, are an 'open shop'; easy to get complete information on and computer tools for. And that fact probably shouldn't be underestimated, especially when buying an older truck.
    Edit: I own, and have yet to ever hear anything truly negative said about the (more recent) 12 speed 'Endurant' automated manual transmission. The previous Eaton automatic models, as I recall from when I was shopping, received less enthusiastic reviews.
    Ssgtkevin, Juanf94 and Siinman Thank this.
  7. ajax1337
    ajax1337 Light Load Member
    107
    67
    Apr 27, 2018
    Overland Park, KS
    There have been issues popping up with the 12 speed, I forget who it was but, someone well known in the space who owns a smaller trucking company and has attending many truck shows recently bought a new 589 stand up sleeper and he spoke about those issues and how you can't spec a 13 speed anymore so they moved to the 18 speed. Something to do with software and clutches. I'd personally spec the Endurant XD Pro transmission if any.
  8. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    I don't see any need or reason for 18 speeds. Autos suck as it is. No need to make em dumber with more gears.
    What I'd like to see is standard rear ends like manuals have. The way they take off is stupid and even more sore that they can't handle a slight resistance.
    Then there's the fact that taking off on the slightest grade they climb to 2200 rpms and hang there.
    Or on the downhill side. They race away and now you've exceeded max rpm. And now the truck dings at you till you shut it down.
    An auto that needs to be manually shifted.
    PFFTTT
  9. ajax1337
    107
    67
    Apr 27, 2018
    Overland Park, KS
    The Endurant XD series that's come out looks promising, I'll say that. From what I hear it's a fully automated system.
