Kenworth T680 CAN communication issues
Discussion in 'Kenworth Forum' started by Roadphoneix, Jun 22, 2019.
  1. Roadphoneix
    Roadphoneix Bobtail Member
    10
    6
    Jun 22, 2019
    I just bought a used 2016 Kenworth T680 May 7th 2019, and by June 6th 2019 I was in the shop for repairs. The issue is when am driving, the speedometer goes to 0mph and the engine fan turns on, after a few minutes, the ABS light comes on and DEF gauge goes to empty and flashes red, the transmission service lights on, the it won't shift out of the current gear.
    Have been to a couple of Kenworth shops, first was in Grand Junction CO, they checked it out saying that it was the CAN and J1939 communication errors, that was being caused by a faulty alternator, and ground wires. Fixed it and paid $3500. Left Grand Junction on Wednesday 12th June.
    On June 14th, just outside Kansas City, the same issue started, took it to another Kenworth shop in Olathe, this time round, it was VTG and NOX sensors, that were the issue, replaced them but the issue was still present, after an ECM swap with another truck, the issue was still present. They did a Pico scope and said that they had found the issue causing the CAN communication and resolved the issue on June 18th. Spent $9500
    June 20th, the same truck issue started again in Arkansas, made it to a Kenworth shop in Memphis TN, this time they're saying it's the batteries that are low on voltage and need to be changed. Currently here. Update with new information as it comes.
    Has anyone experienced this issue before, CAN communication between the engine and transmission, and how did they resolve it? Am feeling that the Kenworth guys are just guessing and when stumped they just clear he errors and send me on my way.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Unfortunately it could just be a broken wire to a terminating resistor at the end of one of the CanBus lines. Problem is tracking it down.
  4. Roadphoneix
    10
    6
    Jun 22, 2019
    Thanks, anyway for tracking it down or it's a try and error kind of thing.
  5. larry2903
    larry2903 Heavy Load Member
    788
    988
    Oct 18, 2009
    On the trails
    Did you get your problem fixed?
  6. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Wow that's a ton of money.. I'm guessing it is an ISX?
    You could have bought a solid running big cam truck for that money, and screw ecm issues. Price of big cam rebuild kit $1500.
    w9l and baha Thank this.
  7. Roadphoneix
    10
    6
    Jun 22, 2019
    Truck update, just picked up the truck from the shop in Chicago. They changed the wiring harness and all looks good. The wiring harness was shorting and they couldn't pin point the issue so I decided to change it. Thanks for all the advice.
    baha, larry2903 and bzinger Thank this.
  8. JRRH2021
    JRRH2021 Bobtail Member
    THE PROBLEM FIXED WHEN YOU CHANGE THE HARNESS?
  9. sjreiff2018
    sjreiff2018 Bobtail Member
    Hey I am having the same issue, did changing the wiring harness fix your problem? Thanks for the reply!
  10. Khalil
    Khalil Bobtail Member
    4
    Mar 7, 2021
    I had the same exact issue on 2018 kenoworth T680 with paccar mx13 Eng and checked all the fuses and relays inside ones and under the hood box with no luck, and after a good amount of time tracing every harness, it ended up being a broken wire on harness that goes from the firewall to the engine , there were a 3 seprete connector for j1939, one of wires was broken
    harkamal81311 Thanks this.
