Kenworth T660 headlight bulb
Discussion in 'Trucks [ Eighteen Wheelers ]' started by aggie1978, Dec 2, 2011.
  1. aggie1978
    aggie1978 Light Load Member
    165
    85
    Mar 16, 2008
    Jackson, MI
    hi all,
    I have a 08 KW T600 and I need to replace the low beams on both headlights
    I do not want to go to the Kw dealer. Does anyone know what the bulb number is for a auto parts store. If not I will just remove one and take it in and match it up.
    The brighter the better
    Thanks in advance for the help
  3. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    Its an H11. if its a halogen that is. D2S if it is an HID. PIAA makes a great replacement for the H11, 15211 for the pair pack.
  4. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Many auto part stores can look up basic truck parts.
    Don't touch the glass of the bulb. Oil from your skin will boil causing the bulb yo burn out quickly.
  5. aggie1978
    165
    85
    Mar 16, 2008
    Jackson, MI
    went to the auto parts store and got me some sylvania silver star and yes they were H11
    Thanks for the help and input
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    you can replace H11 with D2R only. If you use D2S in reflector type headlamp it is a big glare issue!
  7. aggie1978
    165
    85
    Mar 16, 2008
    Jackson, MI
    they are being replaced with an H11 bulb just brighter then stock
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    H11 is 55WT halogen.
    Brighter - HID only
  9. KW Parts Guy
    230
    78
    Jul 16, 2011
    Just be careful, use only brand name premium bulbs, GE, Sylvania etc. Anything that draws more than 55watts will start tripping breakers, blinking lights, melting wires, fire etc. I only recommend PIAA for 'over-wattage' bulbs, they produce a much better light while only drawing stock wattage. And in fact I have found that their lowest price offering has the whitest light, my personal favorite. Just my 2 cents!
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    100 wt bulbs require 20A relays and rewiring with 1.5-2 mm2 wires
  11. KW Parts Guy
    230
    78
    Jul 16, 2011
    I dont know if you can get these where you are Pablo http://piaa.com/Bulbs/Bulbs-9000.html, they also have alot more available out of Japan that we can only get by mail order. No relays needed, only stock wattage, no re-wiring needed.
