I am trying to get a decent working cb in my truck, I’d like to be able to get out 5-10 miles if I could. I have a standard cobra 29 cb and a 4 ft fiberglass antenna and new coax. The swr on the cb (don’t have an external meter yet) reads about 1.2 on channel 19 where I stay. Trouble I’m having is I can only get out about a quarter mile. I am uncertain if I have a good enough ground plane and will run ground straps if needed. Also have been considering going with a longer antenna if that would help. Any suggestions?
Kenworth t600 cb
Discussion in 'CB Radio Forum' started by Xzachtly, May 25, 2018.
Page 1 of 3
81 inch center or top load antenna works best on that truck.
Xzachtly Thanks this. -
Ground, ground, ground! Providing the 29 meter is reading correctly the swr isn't bad. The KW's antenna mounts suck. Everything is powder coated which doesn't promote a good ground.
This is what I did on my t680 and my t880 this weekend. I use 1 antenna on the passenger side with 18' section of professional coax. While running the new coax I start by removing the antenna mount and removing the paint from the underside where the stud goes three the mount. The remove the paint where the 4 bolts attach to the mirror arm. Take the mirror off the truck remove the paint from the 2 bolt hole closest the the engine, and remove a little bit of the paint around the same holes on the truck body. You can also buy a 18" ground strap to run from 1 of the 4 bolt holes of the mount to 1 of the 2 bolt holes at the body. I use a dab of dielectric grease anywhere metal touches metal.
As for the antenna you should use a lease a 5' antenna. We tried 4 different antennas
1. Wilson 2000 swr 2.42
2. 5.5' Francis swr 1.28
3. Predator swr 1.32
4. 5' firestick tunable tip swr 1.03
You have to get away from the KW factory coax and antennas yo get the performance that you are looking for.Xzachtly and rabbiporkchop Thank this. -
Your overall height restriction will be 162 inches. Your mounting bracket is 81 inches above-the-ground, which leaves you 81 inches to work with. For maximum performance you should get as close to that 81 inches as possible without going over your height restriction.
Is that a Hustler antenna in the pics? -
Yes. From the radio to the passenger side mirror. Why? -
J Rich Thanks this.
I was in a 2018 T680 for the past year and used 2 Firestick II 4 footers with better than average results ( nothing great) , the swr was 1.2 and Rx and Tx range was 5+ miles, and it was recommended by Robert at Clays to remove mounting plate and scrape the powder coating underneath, like you did, but I never got around to it. I just moved into this 2019 T680 and currently have two 4.5 foot Procomm Quad wound antennas and they seem to have slightly better range than the Firesticks and the swr is about 1.5, but I have a feeling I may be staying in this truck for a while so I would like to set up a good single antenna.
J Rich Thanks this. -
J Rich Thanks this.
Page 1 of 3
