Kenworth Speedometer lighting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kitchuk, Dec 6, 2021.
  1. Kitchuk
    Kitchuk Bobtail Member
    6
    Dec 6, 2021
    Toronto, Ontario
    2000 Kenworth W900L flat dash i've changed all the gauge lights which were 194's and 1893's but the speedometer seems to have a different light source one that I'm having trouble finding, is it even possible to change the speedometer lighting? I swear I've seen it done in other trucks of the same year.
    Pamela1990 Thanks this.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,856
    Sep 16, 2015
    Ontario, Canada
    There should be 2 lamps in the back of the Speedo head in those two holes. They are a ways in there. Far enough in that I use the pliers on a small Leatherman to grab the lamp holder. They’re the bayonet type push in, 1/4 turn to lock lamp holder. I’ve never seen anything else in a KW speedo unless the one you have is some sort of replacement with LEDs in it they should be there.
  4. Kitchuk
    6
    Dec 6, 2021
    Toronto, Ontario
    That's the problem there's nothing but circuit board in those holes, the tach is exactly what you described but my speedo seems to be different
  5. Kitchuk
    6
    Dec 6, 2021
    Toronto, Ontario
  6. kranky1
    2,253
    8,856
    Sep 16, 2015
    Ontario, Canada
    Well, there’s a new one. My tractor is an ‘05 W900L. Both the original speedo head, and the replacement I put in a few years ago have the 2 holders in them.
  7. Kitchuk
    6
    Dec 6, 2021
    Toronto, Ontario
    I guess I'll just need to go have a talk with Kenworth cause something strange happened
  8. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,828
    Dec 7, 2015
    OK
    This wouldn’t happen to be one with the digital odometer would it?
  9. Kitchuk
    6
    Dec 6, 2021
    Toronto, Ontario
    Yes it is
  10. Slowpoke KW
    1,170
    12,828
    Dec 7, 2015
    OK
    That’s what I was thinking. Your speedometer has been changed and likely lit by led soldered to the circuit board. There’s bound to be a gauge/instrument repair shop that can replace those for you.
