Kenworth power steering help!!!
Discussion in 'Kenworth Forum' started by Arodjasso23, Jul 26, 2019.
  1. Arodjasso23
    Arodjasso23 Bobtail Member
    13
    Apr 18, 2019
    I have a 2006 kenworth t800 with a c13 engine this morning I was going to work and noticed that it is super hard to steer to the right steering to the left is good but steering to the right seems impossible
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Check power steering pump fluid levels, you could have air in the lines.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Check to see that something isn’t bent, drag link, tie rod, maybe there some interference
  5. Arodjasso23
    13
    Apr 18, 2019
    Checked all fluid levels they seem ok. When the wheels are raised off the ground it turns okay but when they are on the ground it’s hard again I replaced all fluids. Could it be the pump or gear box?
  6. boneebone
    2,294
    2,365
    Mar 13, 2009
    Most likely gearbox, if it was the pump you wouldn’t have any assistance turning the steering wheel.
    High Steering Effort in One Direction:
    - Unequal tire pressure.
    - Vehicle overload.
    - Inadequate hydraulic system pressure.
    - Excessive internal leakage in one direction of turn only (of gear box) (verify with internal leakage test).
    - Valve misadjusted.
    blacklabel and Arodjasso23 Thank this.
  7. Arodjasso23
    13
    Apr 18, 2019
    So a mechanic suggested pump changed that and did absolutely nothing. I do notice when I turn the wheel I can hear a cracking noise by the wheel. Could it possibly be a kingpin before I go ahead and buy a gearbox?
  8. Arodjasso23
    13
    Apr 18, 2019
    Replaced both gear box and pump unfortunately still nothing.
    Intothesunset Thanks this.
  9. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Your mechanic is not to bright. Check drag link bind. Or over tighten nuts. Find a real shop to look at your check is all I can say for sure. I have added engine oil to resovoir to aid with more line pressure.
  10. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Jesus, if you can hear a cracking noise start there, well I guess you are pretty much there by now. lol
    Ask your mechanic (just before you get a new one) if he really thinks a pump cares which way you are turning the wheel?
