Kenworth fridge
Discussion in 'Questions From New Drivers' started by Jneeland, Oct 17, 2023.
  1. Jneeland
    Jneeland Bobtail Member
    Oct 17, 2023
    I have a 2023 kenworth t680. If I left the fridge on while on hometime would it drain the battery? If not how many days could I possibly leave it on?
  3. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    The Mack I drive just barely makes it over a weekend with the fridge on.
  4. Espressolane
    16,975
    102,334
    If your truck has “auto start” turn that on. You can then leave the fridge on and won’t have a problem. The truck will start, charge battery and shut off. Just make sure to have plenty of fuel on.
    Flat Earth Trucker and Blagoje Thank this.
  5. Blagoje
    Blagoje Medium Load Member
    441
    956
    Jul 14, 2022
    Paris, Illinois
    I forgot to turn my tripac on one weekend and my t680 made it 2 days with just the fridge on, YMMV
  6. Moosetek13
    Moosetek13 Road Train Member
    14,521
    17,982
    Nov 1, 2010
    Burnsville, MN
    And it might depend on the ambient temp. If it is very warm it will take more power.
  7. seamutt
    seamutt Light Load Member
    115
    269
    Jun 15, 2021
    Another consideration in addition to those given above, I believe, is that running your (lead-acid) truck batteries below about 40% can damage them severely.
  8. Thrasher28
    Thrasher28 Road Train Member
    1,198
    3,307
    Aug 12, 2021
    Bowling Green, KY
    If KW's are like Volvos, it'll cut power to the fridge a little before it runs the battery down enough to not start. Check the inside of the fridge when you get back before you assume all is good and get food poisoning lol
  9. Judge
    84,428
    I leave fridge on over weekends.
    If you’ve hood batteries and it’s not hot out it’ll make it.
    If super hot, Go up Sunday morning and let it run an hour and a half or so while you’re getting groceries to stock fridge.
