as you drive the truck it gets a shake and then a hop and then it feels like it is binding up in the rear. have to accelerate more to get it to go. we have replaced sway bar bushing, both rear ends, wheel bearings, new clutch, new leaf springs, new shackles, rear U joint, and the U joint just off the transmission. Had an alignment done. ran it on blocks and tires are not out of round. drive line is in phase. pulled all four axles and ran a carpenter square and they are all true. tore pto apart and it is functioning properly. can a bad kingpin cause the binding issue?
kenworth dump truck is binding up
Discussion in 'Experienced Truckers' Advice' started by Awhaney12, Oct 24, 2018.
TripleSix and MartinFromBC Thank this.
The Kingpin will cause your front end to hop around but I don't exactly understand how that's related to the rear end binding up. It's easy enough to check your kingpins Just Jack your front end up and put a bar underneath your wheel and see if you have play in the Kingpin.
Did you replace your carrier bearing and have your drive shafts balanced, even the small one between the Rears? -
I would suggest to make sure your bearings are good and that they are adjusted correctly.
Bearings expand when they get hot, and if they are adjusted too tightly they won't roll freely and you will burn them out.
And if your carrier bearing has play then you should replace it. -
You didn't mention replacing the Ujoints to eliminate them. Checking the pinion shaft for play and tightness.
JohnC123 Thanks this. -
BoxCarKidd, JohnC123 and MartinFromBC Thank this.
