I'm looking to buy a truck in the next 5 months or so. I've been doing research on engines, makes and different years.
So far the only definite decision I've made is that I want PRE EGR. So this conversation will pertain to truck 2003 and older.
The information I'm looking for is this:
Is there really a huge difference between the T series KW's and the W9?
Or is it just an old school style/ego thing?
Are the 2003 and older T series trucks reliable?
Thanks
Kenworth Comparisons
Discussion in 'Ask An Owner Operator' started by Third3y3guy, Mar 19, 2015.
Page 1 of 3
I have a 2003 T600 the cab/sleeper is exactly the same as a W900. Only difference between the 2 is the W900 has a longer hood. Careful with any 2003 year model tractors as you could end up with a CAT bridge motor engine serial # prefix MBN or an ISX Cummins with EGR. Or you could get an '03 with the the pre-emmisions serial prefix 6NZ CAT or non-EGR ISX Cummins. Obviously you want to avoid a CAT bridge motor like the plague and/or getting an EGR ISX defeats your whole intention on this purchase. Educate yourself. '03 is a mixed bag '02 or older is clear cut.
Trugrace, Third3y3guy, 88 Alpha and 4 others Thank this. -
What Rolling Coal said. For a given model year, the T800, T600, and W900 are the same truck inside. Only one that's different is the "wide body" T2000 which has TONS more headroom, more width, more room between the seats and more cabinet space.
T600 and T2000 have alot of fairings and stuff that seems to wear out and shake. The fancy expensive aerodynamic mirrors don't last (glue comes apart and the glass vibrates).
I'll take the W9 and T8 for durabilty.
Sorry 'Coal. I don't mean to bash your truck. I liked my time with our 1995 T6 but I got tired of fixing the shaky mirrors and got tired of taking the fairings on and off to pressure wash the salt of the fuel tanks. We found if you don't do that up here the fuel tanks corrode. We have an '08 T660 that's about to get it's third set of tanks. -
No you're spot on. I've had to replace broken brackets that hold fairings on that were welded by the previous owner because they broke. Down at the bottoms where they fit snugly and pivot out some of those points have shaken for so many miles they're busted and without some strategic baling wire application on the back sides of the fairings they'd be flopping in the wind. The mirrors suck exactly like you said. Kenworth has the most ingenious (not!) way of attaching stacks to a cab. I will say on the inside the old girl is still relatively tight and they do put together a good sturdy cab imo. It is easy to work on too except for crawling under it because of the fairings. With the benefit of hindsight I would pick a T800 or W900 over a T600 if I had it to do over again. When I was a kid in the 80's and anteater's first came out I thought they were the coolest truck and always wanted one. Yeah that's why I got a T600 lol.
rank Thanks this. -
Whatever KW you get, make sure it has gauges instead of idiot lights. It should have 20-22 gauges on the dash.
Bean Jr., Third3y3guy and rank Thank this. -
Most guys out here on the road wouldn't kno what 16 to 18 of those gauges were telling them Six.
SL3406, rank and OLDSKOOLERnWV Thank this. -
The new T680 is supposed to be very reliable and well built.
mp4694330 Thanks this.
Bean Jr. and Third3y3guy Thank this.
Page 1 of 3
