Kenworth basically does away with duel exhaust
Discussion in 'Ask An Owner Operator' started by Cat sdp, Jan 30, 2018.
  1. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I heard about this but finally saw it for myself... this is a new 880
    This is the drivers side lower exhaust
    This is from the pass side the dpf is on the right . The open drivers side exhaust pipe is on the left.There’s no cross over pipe.
    They must be out of their minds........
    Toomanybikes and Crude Truckin' Thank this.
  3. AZ Pete
    AZ Pete Medium Load Member
    483
    853
    Dec 27, 2017
    So they still have two but one pipe is a dummy pipe?
  4. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Most new trucks have got rid of stacks in place of the trendy grass burner set up.
    Crude Truckin' Thanks this.
  5. supersnackbar
    18,618
    44,807
    Aug 19, 2007
    Your Town, USA
    I have wondered for a while why I see some trucks where one stack is putting out exhaust and the other isn't (usually when it's really cold and one is steaming and the other isn't)...now it makes sense.
  6. Blu_Ogre
    Blu_Ogre Road Train Member
    8,103
    47,623
    Jul 14, 2013
    Out west
    Fashion over function...... The DPF and Catalyst cut the flow so much you only really need one pipe. The second is purely fashion statement and poorly located ballast.
    ReeferOhio and Crude Truckin' Thank this.
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Peterbilt has done the same on the trucks with over the frame exhaust but the 389 with the under the frame exhaust still run a y-pipe.
  8. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    You guys see any of the three stack trucks ? Two dummies on the side , and the real one running up the back of the cab .
  9. Roberts450
    2,237
    3,635
    Feb 6, 2016
    Ive seen a 389 done that way but with a weed burner cause they didnt wanna turn the 8" stacks colors from the heat of the DPF.
  10. Blu_Ogre
    8,103
    47,623
    Jul 14, 2013
    Out west
    A double penile extension?????
    JoeyJunk Thanks this.
  11. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,501
    Oct 22, 2016
    North Dakota, Eh?
    I'd rather sport a single stack than try faking duals. Plumb propane into it and have some fun at least.
    Scooter Jones Thanks this.
