Kenworth 8 bag air ride pros and cons
Discussion in 'Trucks [ Eighteen Wheelers ]' started by OLDSKOOLERnWV, Jan 27, 2016.
  1. OLDSKOOLERnWV
    17,806
    268,393
    Looking at a 95 W900 with 8 bag KW suspension that has the aluminum "elephant ears", any advice of pros and cons from someone more experienced than I am with them? Everything suppose to be ok but just curious as to what may be unseen that I need to pay attention to. Appreciate the thoughts.
    This would not be for off road.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Rides rougher than the 4 bag and does not drop anywhere near what a 4 bag does when you drop the suspension.
    Oxbow and OLDSKOOLERnWV Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I've had 2 trucks with this suspention.
    That should be ag100.
    I found it to be one of the best riding suspentions I've had. It was also very low maintenance. It is also one of very few suspentions that has no torque rise. So it always keeps u joint angles in spec.
    Only negative I've found is they don't handle very good. If your heavy and high over the fifth wheel it does have a tendency to lean in the corners.
    Other then that not a bad suspention.
    Oxbow, Ruthless and OLDSKOOLERnWV Thank this.
  5. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You might be talking about the ag400
    They had smaller bags then the 100 and they rode chappy. The ag100 rides perty nice. I'm assuming this is what he has if his truck is a 95
  6. cnsper
    5,869
    27,421
    Feb 28, 2014
    Could be. We have 46k rears in our trucks and the 8 bag are #### near the same as the walking beams we have.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    What year are your trucks?
    I do know when they went away from the ag100 to the new style people really complained about the ride. It was terrrible.
  8. OLDSKOOLERnWV
    17,806
    268,393
    This truck is a 95 Glider actually, so not sure what exact year the rears are. He did say it had the aluminum elephant ears.... Suppose to be an older setup from what he told me.
    Oxbow Thanks this.
  9. OLDSKOOLERnWV
    17,806
    268,393
    I can always change it out later, just don't want to get into right now. Just need to put it on the road and move on. Have a job with a local dispatch pulling stretch trailer and Lowboy. The 1987 K100 I drove for H&W years ago wasn't to bad really.
    Oxbow Thanks this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Elephant ears? Do you mean the big bracket That hangs from the frame between the axles? My opinion is they are better than the steel ones. They don't tend to Crack like the steel ones do. What kind of tortion bars? Round ones are ag100, wish bone is ag200, flat bar is ag400.
    Oxbow, Ozdriver and OLDSKOOLERnWV Thank this.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    95 should be the 100. The lower bushings don't last very long . And need to be replaced often.
    Other than that issue I liked it had a 96 kw with it....
