Keeping Frac Sand Hoses Clean and Dry Inside while in Transit
Discussion in 'Experienced Truckers' Advice' started by grumpyoldlady, Oct 25, 2011.
  1. grumpyoldlady
    grumpyoldlady Bobtail Member
    9
    Henderson, Tennessee
    I'm interested in knowing how other drivers who haul frac sand keep their hoses from getting moisture and road dirt in them when they are rolling? I've heard there are caps that fit over the ends and keep the hose opening dirt/ice/water free. What do YOU do to keep these out of your hoses?
  3. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    When I was pulling a tanker if I didn't have enough caps for the hoses I would use plastic baggies over the ends and secured with rubber bands. For 3 & 4 inch hoses you'll need the gallon size. The smaller bags will work on a 3 inch male fitting but not on a female.
  4. wis bang
    wis bang Road Train Member
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    WE used to roll up cement hoses 'n strap a bungie around the roll clipped onto the female end's cams. Chem Leaman had boxes mounted to the tractor frame where you could carry two rolled up hoses.
  5. pathfinder1361
    pathfinder1361 Light Load Member
    256
    40
    Aug 19, 2011
    miami, fl
    hey there!
    did you used to work for chemical leaman? i used to work for them in bridgeport, nj. in the late 80's. good times :biggrin_2556:
  6. pathfinder1361
    256
    40
    Aug 19, 2011
    miami, fl
    howdy!
    can i ask what matlack terminal you were at?
    ex-chemical leaman here, bridgeport, nj
  7. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    Either get with the company and get the number of hose caps or get trash bags and cheap bungee cords to cover them with.
    Does it really matter if a small amount of trash makes into the wells?
  8. Johnny99
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    I worked there out of the Columbus Oh terminal from the mid 80's to mid 90's. When I first went to work there it was a lease operator terminal run by the guy that had owned Coastal Tank Lines {Howard Ryder, Nuco Truck Lines} before they went broke and CLTL bailed them out. After Mr Ryder went broke again all the Nuco terminals were absorbed by CLTL and we became company employees. Stayed there until just before they were taken over by Quality.
    We delivered waste water and filter sand to Dupont in Deepwater NJ, just up the road from you. I cleaned out in Bridgeport a few times.
  9. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    no experience with frac sand here but,
    when I pulled milk tank the tank washes bagged the ends and just used a rubber band to secure the bags, never any issues..
  10. haulhand
    haulhand Road Train Member
    I always just pack them in hose trays and don't worry about it. The little bit of road grime they pick up isn't going to contaminate a well I mean look at the units you blow into be it a sand king or a mountain mover or a sand chief they aren't sealed units and they allow dirt and water in. When they move sand to the blender it is just on a conveyor and open to the elements. So the little bit of #### you get in your hoses won't really matter.
  11. wis bang
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    Driver trainer, dispatch & TM @ Woodbridge, spent a vew visits @ Sweedsboro & Bensalem. Went back to the Grasselli DuPont plant as TM when they threw out Conoco.
    My Uncle ws the CLTL Regional Manitenance MGR @ Stockertown, PA ; I worked (2) summers @ Stockertown [utility mechanic] & one at Nazareth, PA [rebuild shop] during college and I was working for a petoleum carrier when I got the chance to go to Grasselli.
    CLTL dispatcher at Grasselli, NJ [DuPont] 1978, went to Central dispatch [Dowiningown and Lionville] in 1980 then dispatch at Croydon b/4 a layoff in 1982.
