I ride with my husband 24/7 and he is a company driver of approximately 6 months. His company is really riding his ##s about his fuel mileage and not idling the truck. We are in Oklahoma today and it is hot as a ##### in church! With two turbo fans and the windows down, it is still unbearable. Do any of you experienced drivers have any ideas as to ways to keep cool in the summer? I understand that diesel prices are at an all-time high, but it has got to be 100 degrees in the sleeper. Help!
Christina
Keeping cool in the truck?
Discussion in 'Experienced Truckers' Advice' started by Greeneyedeinstein, Mar 27, 2012.
Page 1 of 4
Yes I do, start looking for a decent company. If you "live in a truck" there human standards that must be met. Sounds like a change for you guys.
Numb, Motownfire, lilsister and 2 others Thank this. -
I feel the same way. Unfortunately, it isn't going to be easy to get a job that pays as well as this one does with only 6 months experience.
The temp map looks like it is only in the mid 80's there today, thats not even hot weather for there! Do you have a reflective sun shield you can put in the windshield? They are less than $10 at Walmart, and will make a world of difference. Folks that don't run the AC tend to head to the back row or sparser extremes of the lot to seek shade or get away from being beside other running trucks and the huge amount of heat they put out.
SHC Thanks this. -
If u are uncomfortable then idle the truck. Boss' will complain, that is their job. You have to be comfortable to get proper rest and if they do not supply you with an APU then just idle. I have to pay for my own fuel and i still idle my truck if i am sitting for the day and its warm out. I also have a dark blue truckwhich does not help the fact, and even on a day that is 70* outside, if the sun is bearing down on my truck then its most likely 90* inside my cab.
Numb, flightwatch, striker and 5 others Thank this. -
You're going to need a reflective sunshade for the windshield, and every window in the truck.
Also, keep in mind the position of the sun and the time of day. If you can get the trailer or load or headache rack between the sleeper and the sun, it'll keep some heat off.
Be conscious of when you're stopping. Max out the A/C the last hald hour before parking, and if possible, shift sleeping hours towards the night.
Other than that, about all you can do in a company truck is keep the ice box full, get some 100% cotton bed sheets, and get those clothes off once the truck is parked and those reflective shades are up.Greeneyedeinstein Thanks this. -
Yes, it may be 80+ degrees outside, but it has got to be high 90's, 100 degrees inside the truck. We had not thought of the sun-shield, although we do have the curtains closed to keep the sun out. I also didn't mention that the "bunk a/c" does not work. Neither does the heater.
Thanks for the back row idea. -
I'm just hoping it cools down some once the sun goes down! But of course, this is the South and that usually isn't the case. You'd think I'd be use to this, being from Texas and all. -
We did idle for a bit to get some cold air circulating for the fans. We do not have an APU in this truck. We do not have an inverter either. Well, actually, we have one but have not been routed back to the yard since he started to have it put in by one of the mechanics (company policy or some crap), even though we have asked and mentioned it many, many times.
I think I'll take your advice and just ask him to idle. -
The sun reflector is going to be more efficient than your curtains in reflecting the heat and not absorbing it.
Page 1 of 4
