keep loosing axle seal
Discussion in 'Freightliner Forum' started by rtyauch301, Sep 20, 2013.
  1. rtyauch301
    rtyauch301 Bobtail Member
    20
    Mar 29, 2011
    Athens, Alabama
    I have a 2014 freightliner cascadia i have lost the front right drive axle seal for the 3rd time. the truck only has 66k on it lost the first one at 22k the 2nd at 37k and now for a 3rd time at 66k do you all think the shops are doing something wrong or do I have a problem with the axle
  3. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Incorrect wheel bearing torque? Unitized hubs?
    Same dealer fixing it every time?
    Edit: I just realized you said drive axle..... Scratch the unitized hub comment.
  4. rtyauch301
    20
    Mar 29, 2011
    Athens, Alabama
    No im OTR so 2 different dealers one in Connecticut and one in Virginia usually just go where ever I can get in quickest under warranty just trying to figure out what to do when I go see them this time 3 times in 66k is way to offen
  5. flyingmusician
    flyingmusician Road Train Member
    4,288
    10,905
    Feb 25, 2011
    Jamestown, NC
    Mine did the rear left drive at only 12k. That was 2 weeks ago. Keeping a close watch on them all and even more so after reading this post.
  6. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    I would certainly check to see who you talk to about this being an issue? after the first time they should have had it fixed! But since they didn't would be finding out what the warranty department is going to do ffor this on going issue.
  7. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    Which axles does it have? Meritor on the ones we run and no troubles like those you mentioned.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Do you all have Cascadias or Coronados? Premature seal failure is due to shaft wobble whether it be worn bearings or a bent shaft.
    If all these trucks are newer ones than the dealer should be doing the work so they can record the repeated failures in their database.
    The first thing I would do is jack the rear end up in the air and see if the tires are turning true. If it wasn't then I would pull the axle and see if it's true. If it was I would focus on the bearings. If the shop is just replacing the seal they are just fixing the failure and not finding the problem. I would make it known to the shop that this is a repeated failure and not just a leak. Otherwise they won't dig further.
    It could be a part design issue and a weaker metal used in a particular brand axle. It could be because it's now a Daimler product! :)
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    after having some issues any more if i have to have a wheel seal done i have new bearings and races put in regardless of what they look like
  10. richardj87
    richardj87 Bobtail Member
    31
    9
    Aug 24, 2013
    dsm Iowa
    check the axle breather make sure it isn't pinched or plugged off in anyway
  11. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    I'm unclear about what seal is leaking. Is it the wheel seal (oil contaminating your brake drum and shoes and showing up on inside of inside tire) or is it the drive flange seal (oil leaking onto the outside of your outside drive wheel and outside of that tire)?
