kane transport-tanker yankers
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by dieseldan2005, Dec 28, 2010.
  1. dieseldan2005
    dieseldan2005 Light Load Member
    185
    17
    Feb 6, 2009
    North Branch, MN
    Anyone up here in MN, IA area have any experience with these guys? I know that they are a pretty big tanker operation and seem to have good equipment. I was looking at going O/O with them or wayne transports. I know wayne has a good reputation but i want to explore all my options. Any opinions would be great. Thanks!
  3. trkinDave
    trkinDave Bobtail Member
    7
    Jan 9, 2011
    I have worked for Kane for 4 years. I am a company driver but know they are looking very hard for drivers. They have several divisions but during slow times they overlap each other. They also run in Canada if you are interested. They are a very good company and you will be required to put electronic logging [peoplenet] in your truck. Good luck with your looking and email me if you need anymore info.
  4. trkinDave
    7
    Jan 9, 2011
    Dieseldan tried to reply to your message but cant since I have only posted once. U have to post 7 times to be able to respond. Thanks and B Safe
  5. Febreeze
    Febreeze Light Load Member
    54
    26
    Sep 30, 2012
    Just started with Kane. I like them. They seem to be straight forward in their dealings with people and are always hiring it seems. Their equipment is decent as well. (Hope you like yellow.) =)
  6. c_squared0718
    c_squared0718 Bobtail Member
    @2012tanker. I looked at there rate of pay and it doesn't specify how much a starting driver will make. It just gives the percentage increases during weekends and holidays. Can you give me a detail of how much a driver will make starting off with them?
  7. trkinDave
    7
    Jan 9, 2011
    Your starting pay is the same as my pay after 5.75 years with them. If you pull loads out of different locations the pay scale increases as Kane pays a combination of % of load converted to cents per mile. Usually after your head quits spinning you figure it all out!!!!!! Yes they do pay more for weekend work and holidays. Depending on the amount you want to work, ie; be on the road more or home more, you can make in the mid $60s to low $70s or as little as low $30s. They will keep you busy as they need those wheels turnin to make money. Hope this helps. Dave
