How much juice would a generator need to start a rig with dead batteries? Also, does anyone know of any portable starting devices that would be powerful enough to jump a truck, something you could carry with you in the sidebox perhaps? It would be nice to have something I could carry on the truck during the winter just in case, especially since roadside costs an arm and a leg. I know I see portable starters in some truck stops and auto parts stores, but a lot of them look like a waste of money.
Jumpstarting a truck with a generator?
Discussion in 'Experienced Truckers' Advice' started by armybravo, Jan 3, 2009.
Page 1 of 4
he meant like the carry around jumpstart generators that u can use on cars, most are junk or work once.... is there one out there powerful enough to crank over the tractor? used ...tested by someone on here
Native Dancer Thanks this. -
kylefitzy, Blue Zombie Trucker and tscottme Thank this.
There are booster packs out there rated for commercial vehicles. Rescue brand booster packs can be had rated for 800 amp starting current and 1500 amp peak current. That may do the trick, but you will have one shot at it, perhaps two. The trouble with battery packs and booster packs is the reduced battery capacity. A commercial vehicle will drain a booster pack in a heart beat. Carrying two fresh batteries is as viable as trying to get a booster pack with enough power to reliably start a class 8 vehicle in cold weather. Cheaper and only slightly more bulky as well.
easiet way as said above is four new ones i replaced all four of mine last year cost was like 400-500 bucks .
But trick I learned in carhauling if you want backup buy 2 of the 12 volt battery jumper packs with the switch to jump to 24 volt.
One charge they will last for months I run into cars that i had to jump to get on and jump to get off used on my truck the one time when the batteries died.
Then jump from the starter much easier then messing with the batteries and all that bs
wow why is dude banned in 6 hours lolLast edited by a moderator: Jan 5, 2009
Hey, I would like to know the answer to what the question was, :
How do I start my rig with a generator?
I'm stuck with a dead battery right now battery pack gone, but my honda eu2000 is working and with me. How do I accomplish jumping My truck with it? -
About the only option you have with that generator is to buy a smaller 12 volt battery charger and let the truck sit on charge for a couple hours. Generator might be able to handle a 45 amp charge rate at best but I don't think it'd support a start boost.
wore out, Blue Zombie Trucker, Goodysnap and 1 other person Thank this. -
No one is around who will help you out?
@Rhett289
Page 1 of 4
