Mostly happens under a load or on a incline. Flat road is a breeze but if i have to pull off on a incline it will jerk really bad. I’ve had to back down on a flat road from a incline just to pull off once. I already gotten clutch adjusted etc.
Jerking clutch pedal mostly under a load?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Isxrookie, Mar 31, 2022.
Is the pedal pulsing or the truck jumping?
Either way I would guess your flywheel or separator plate is warped. Could also be the actual pads themselves on the clutch disc. I have seen them warp on ag tractors and make it very hard to control things kinda not much and then grabs. Does it do the same thing in reverse if not possibly a motor mount issue look closely at the ones on the sides of the flywheel housing -
What gear are you using? Sounds like too high a gear for the situation.
Dino soar, Magoo1968 and God prefers Diesels Thank this. -
Mine was like that when I bought the truck. I put in a new clutch. Old clutch still had a lot of friction material left, but the new clutch fixed the problem. I adjusted mine as well, and it didn't help.
Are you saying it's real touchy, like you can't feather it? Basically "all or none"? -
Good point I guess I assumed that the guy in the seat new about that but come to think of it that’s a pretty common situation
God prefers Diesels Thanks this. -
Not sure what was wrong with my old clutch, because it looked fine visually, but the new clutch fixed it. Refaced the flywheel and did rear main seal at the same time.W923 Thanks this. -
