JAKE BRAKE POPS LOUDER THAN NORMAL
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigstank, Jan 20, 2016.
  1. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    Hey guys need some help here. I got an 03 379 with a 6nz cat. I rebuilt the motor a year ago and i didnt change the cam cause it looked fine. SoI just had to replace the camshaft and rockers including the injector rockers. Now the problem I have is the Jakes pop alot louder on these 8" straights and I seem to have a vibration only when the Jakes are on. Is it just cause everything is new and tight? Also here is a picture of why I had to replace the camshaft with a stock reman. Thanks for your info guys!
  3. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    I don't have a lot of experience troubleshooting Caterpillar engine brakes but a Cummins can show the same behavior. A cracked slave piston adjusting screw or the lash setting excessive can cause this. Can you narrow it down to which engine brake position by using the dash switch?
    bigstank Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Two things come to mind. Adjustment and something in one of the jake housings is wrong. You can get a (tune up) kit for the jake and you don't have to take them off to do it.
    bigstank, wore out and SAR Thank this.
  5. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Yeah idk it's probably just the the overhead being new. I'm gonna rerun the rack probably next week and see. I had the jake packs rebuilt with all new springs ect.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I just want to add this. when you change the springs from that kit also pull out pistons and mark them. you may see scratches on pistons and inside of the housing. polish these surfaces slightly and put back pistons as marked.
  7. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Yep, it was done correctly
  8. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Ya didn't clean your ears lately, huh? Jakes can get out of adjustment and they probably working right now for first time in a while. Be my bet.
