Can I use a Dodge Ram 4500 to pull a 16000 GVW gooseneck trailer if I only have a DOT health Card/?
My load is way under the 26K, but the the Dodge GVW is 16500 lb and the Trailer's GVW is 16,000lbs and that adds up to 32.5K but my total dry curb weight is only 12.500 and with the load I am only at 20.000
Dodge curb weight is less than 7500 lbs
The Trailer curb weight is less 5000 lbs
12 500 total dry curb weight
7500 lb load
20,000 total weight
The truck and trailer total GVW is 32500, but only weighs 12,500. Can I drive it empty without a CDL?
Am I okay if my total weight is less than 26000 or does the total GVW of 32500 ruin my plan?
Thanks
Granny DP
DPForumDog
It this legal?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by DPForumDog, Dec 28, 2022.
No, not in a commercial capacity the CGVW exceeds 26,000. That is what they go by.
Thanks. That what i figured. Guess I was just wishful thinking.
IH9300SBA Thanks this. -
The power unit can be plated/registered for 26k meaning the truck and trailer can't weigh more than 26,000 actual as it rolls over a scale, but that is not what determines whether a CDL is required for the driver. It's the GVWRs of the truck and trailer combined that determine it. For example with your 16,500 lb rated truck, you would only be able to pull trailer rated at 9,500 lbs to stay under the CDL threshold. This is why large 2-axle box trucks are usually never rated higher than 26k GVWR.
Read what is required. It's over 26K truck + 10k trailer. You can actually run 36K GCWR without a CDL, but 1 pound over 26K for the truck or 10k on the trailer triggers CDL requirements. -
For a class B it’s over 26k single unit and a trailer no more than 10,000 pounds.
You trying to be smart with your word play is going to get someone confused or even worse jammed up with a ticket. If they get on a scale with 35,000 they are most certainly about to have a #### day. All because you are trying to look smart.Dino soar, blairandgretchen, Tb0n3 and 2 others Thank this. -
Jubal Early Times Thanks this.
From Federal Register :: Request Access
Combination Vehicle (Group A) - having a gross combination weight rating or gross combination weight of 11,794 kilograms or more (26,001 pounds or more), whichever is greater, inclusive of a towed unit(s) with a gross vehicle weight rating or gross vehicle weight of more than 4,536 kilograms (10,000 pounds), whichever is greater; or
(2) Heavy Straight Vehicle (Group B) - having a gross vehicle weight rating or gross vehicle weight of 11,794 or more kilograms (26,001 pounds or more), whichever is greater; or
Now lets look at a state Pennsylvania , because it's the first google hit and it follows federal rules.
https://www.psp.pa.gov/law-enforcement-services/Documents/CVSD/CDL Flowchart 5.29.14.pdf
!. Is this a combination vehicle - YES.
2. Does the trailer have a GVWR of 10,001 or more pounds? - NO (Remember I limited it to 10k lbs and even said 1 lb more triggers CDL)
3. Does the power unit have a GVWR of 26,001? - No
4. Is the vehicle designed to transport 16 or more passengers including the driver? - NO
5. Does the vehicle transport placardable amounts of hazardous material? - NO
- No CDL Required
Yes I know California is convoluted, but even their flowchart shows the same thing....
Here are a few more flowcharts directly from the states DMV (or equivalent) site to show it.
Connecticut - https://portal.ct.gov/-/media/DMV/CV_Bulletins/CDLFlowChartpdf.pdf
Arizona - https://azdot.gov/sites/default/files/2019/07/CDL-Med-Cert-flowchart.pdf
California (Who's is probably the most complex) - https://www.chp.ca.gov/CommercialVehicleSectionSite/Documents/Driver License Flowcharts.pdf -
I’ll say it again. You are playing word games. Yes technically you are correct. There I said it. See I’m not above saying you are correct. However. For you to be correct and for the OP to be able to technically load 36,000 and not need a cdl he would have to have a power unit that is loaded to 26,000 and a trailer that is loaded to 10,000. So basically a box truck and a uhaul trailer. So while you are correct, you are not offering any helpful advice. Because you know full well that that isn’t common combination except in the uhaul rent a truck world.
How is reading the law a technicality?
Oh wait, it's not!
And yes, knowing the law is useful. Sorry you can't admit that.
