It got a little cold out and my isx15 is whistling. Is this normal?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by circle h, Oct 13, 2021.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    Cold the idle has gone up to 760 and it's generating a bit of boost, so you can here it whistle. Is this normal for an isx15? It's a 2016 with 500k on it and new to me. Thanks
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    140,747
    When it regens it will boost the rpm up and make about 5-10psi of boost
    skellr and circle h Thank this.
  4. circle h
    240
    375
    Oct 22, 2020
    The engine is stone cold. Is it trying to regen cold?
  5. D.Tibbitt
    140,747
    If the engine wants to regen and not at temperature , it will raise the rpms up to build heat until it reaches the temp where it will start a full regen.
    circle h Thanks this.
  6. circle h
    240
    375
    Oct 22, 2020
    Thanks. I'll take it a distance. Done nothing long enough to get it hot.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Is the wistle consistent or does it change or come and go with RPM/ Boost while driving?
    Warm its gone?
  8. circle h
    240
    375
    Oct 22, 2020
    It goes away when I bring the idle up. I haven't driven it since it did it yesterday. I got home from a short 3 mile no load trip, parked in the lot started it two hours later to put it in its garage and it did it for the first time. Started it today and cold it did the same thing. Bring the idle up to 1000 and the boost and whistle go away.
    Goodysnap Thanks this.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Hard to say for sure without hearing it. Some call a normal turbo noise a whistle.
    More common would be an exhaust manifold gasket cracked and leaking. Inspect for soot trails (black streaks) around the manifold to cylinder head, especially #2 and #5. When the exhaust back pressure leaks by the bi-metal gasket it whistles like a blade if grass between your thumbs.
    A5¢ and circle h Thank this.
  10. circle h
    240
    375
    Oct 22, 2020
    Thanks, I'll have a look.
  11. circle h
    240
    375
    Oct 22, 2020
    I drove it today, got it up to temp and ran about forty minutes. It still does it, warm or cold. Whistle must just be turbo whine. It goes away off idle. Why would it be kicking the idle up to 760 and adding boost?
