Isx15 cm2250
Discussion in 'Peterbilt Forum' started by chicknwing, Feb 14, 2014.
  1. chicknwing
    chicknwing Medium Load Member
    526
    601
    Jan 4, 2014
    Charlotte, NC
    Anyone care to take a look at the ECM download for me? A little concerned about the DPF filter reading and 2 of the inactive codes.
    This is in a 2012 587 ISX 15 @ 485 18 speed (single over) 1850 ftlb torque 3.55 rears.
    Codes: 101 Crankcase pressure - Data valid but above normal operation range - Most severe level
    101 Crankcase pressure - Data valid but above normal operation range - Moderately severe level
    DPF - Maximum Diesel Particulate Filter Differential Pressure - 5.6 inHg
    Maximum Diesel Particulate Filter Soot Load - Above Normal Moderately Severe
    ECM shows mileage @ 332869
    Avg fuel mileage shows 6.7 mpg
    View attachment Pete ECM Download.pdf
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
  4. chicknwing
    526
    601
    Jan 4, 2014
    Charlotte, NC
    Yeh I had read that thread in it's entirety. Lots of good info in there. Was looking for someone to confirm/deny my fears about the DPF filter. I know I read somewhere that a reading above 4 was unacceptable.
  5. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    What reading are you getting on your dpf differential pressure sensor key on engine off? You could have a stuck sensor. The tubes going to the sensor could also be plugged
