ISX turbo/exh manifold combination T6
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Vurtle, Jul 23, 2015.
  1. Vurtle
    Vurtle Light Load Member
    69
    39
    Mar 9, 2012
    Tx
    Does anyone sell an exhaust manifold that is a true T6 flange for the ISX? We purchased a PDI exhaust manifold because their rep confirmed it had a T6 flange. We get the manifold and find that they are using larger turbo studs than a T6 flange causing our BW 171702 not to fit unless we drill our turbo flange holes bigger. It is frustrating. We get our BW171702 turbos for under $700 and we prefer to stay with that turbo. I just installed a Bullydog 12.7 manifold and they stayed true to the T6 measurements. I am hoping someone out there can point me to whoever makes an ISX manifold with a true T6 flange. All this proprietary crap is frustrating and makes me not want to buy someones product. I may have to use an 870 manifold with an HX55 to T6 adapter from CPP.
    This is on a pre EGR ISX
    PDI manifold also does not allow the factory oil supply and drain lines to line up in their original location.
  3. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    Why dont you just drill your turbo flange holes bigger? I just had the same deal on a 3406e with the new PDI manifold. You need to go up an 1/8" on the mounting holes.
    Vurtle Thanks this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Is it posible to just get some studs that have a smaller dia on one end ?
