Isx oil pressure low?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vivaspin, Dec 19, 2020.
  1. Vivaspin
    Vivaspin Bobtail Member
    27
    8
    Oct 2, 2020
    Hello I have an international prostar with Cummins ISX and about 900,000 miles has had in frame overhaul about 250,000 miles ago
    I have had this truck for the past hundred thousand miles and my oil pressure has always shown between 28-31psi cruising 70mph. Idle 12-13 psi
    Has a lot of power and no issues. I just
    Want to know if this is normal oil pressure or should I replace some thing
  3. Vivaspin
    27
    8
    Oct 2, 2020
  4. AModelCat
    154,214
    If its been like that for 100k and no problems, why worry now?
  5. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    I have an ISX cm 2350 Mine holds 40 - 45 cruising at 70 mph. And around 25 at idle. It has 610,xxx. On it.
  6. Vivaspin
    27
    8
    Oct 2, 2020
    i drove a buddys prostar last week same engine cm871, he was getting 35-37 psi at 70mph.
  7. Vivaspin
    27
    8
    Oct 2, 2020
    Yea im getting nowhere near that.
    cold engine: idle 30psi and at 70mph i get 40psi
    Warm engine: idle 12-13 and at 70mph i get 28-31psi
  8. AModelCat
    154,214
    Put a proper gauge on it first before you panic. Dash gauges aren't really accurate.
    70 mph means nothing. Oil pressure is RPM dependant.
    jbatmick and bzinger Thank this.
  9. Concorde
    Concorde Road Train Member
    4,341
    15,391
    Jun 29, 2016
    West Melbourne Florida
    2021 Cummins 565hp..@850 rpm idle..just shy of 30 psi.
  10. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    2007 cm 870 when I overhauled it put in a new oil pump it was 22# at idle and 32# running down the road.
  11. Vivaspin
    27
    8
    Oct 2, 2020
    Appreciate it guys thank you
    more info:
    65mph 1400 rpm : 31psi
    70mph 1500 rpm : 29psi
    75mph 1600 rpm : 28psi
    shouldnt it be the opposite, the more rpms the more psi.
