Isx in derate mode showing codes Engine 0 Fail 31 5246 1569
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lilbit01, Sep 3, 2018.
  1. Lilbit01
    Lilbit01 Bobtail Member
    4
    I have a Cummins isx it's in derate mode it's showing codes on my dash which are Engine 0
    Fail 31
    5246
    1569...i had the dpf/doc cleaned i changed the i map sensor also, i also did a park regen on it but after i drove it for about 30 minutes after that the yellow engine light came back on and once I stopped & shut it off then restarted it now the red/yellow light is on and in debate mode could someone please help
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    @Justrucking2 may have an answer.
    Probably an emmision, or def code?
    I've been in derate for 4 weeks mx 13. For egr code.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Those codes are for the actual derate, they don’t specify what triggered them.
  5. Lilbit01
    4
    Looks like I see a 543 on the dash if that any info on helping me ...the def doser valve has a lot of white stuff Aron d it also, could that be the problem?
  6. Oldironfan
    5,777
    5,541
    May 22, 2017
    That white stuff is dried def.
  7. Lilbit01
    4
    Wow thanks, maybe its in derate because it needs a new doser valve, is it anyway to get it out of derate so i can get it to the shop, also it's a auto, I heard on manual the speed sensor could be unplugged but I'm not sure with automatics
  8. mobilerepairboise
    mobilerepairboise Light Load Member
    61
    42
    Jul 10, 2018
    Boise Idaho
    On Volvo D13 u can unplug speed sensor I’m not sure about Cummins
    Lilbit01 Thanks this.
  9. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    I think you can unplug both ABS fuses and it'll get you home
