Isx cummins codes, 136:f05 sid081_a and 128:f04 sid232_p, help??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Marcus40, May 6, 2019.
  1. Marcus40
    Marcus40 Bobtail Member
    Can anyone help me with a code I have on a 2005 isx cummins 136:f05 sid081_a
    128:f04 sid232_p
  3. Midwest Trucker
    5,912
    21,382
    Aug 31, 2018
    No idea, call your local Cummins shop.
    Marcus40 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    What kind of truck and what are you using to read codes? The format you are using is not correct. The 136 is the source address of the ABS, 128 is the address of the engine. If you have an International, and you are reading this from the LCD display, you are not reading fault codes. These are fault messages and those are different and are not to be used for troubleshooting.
    Marcus40 and QUALITYTRUCK Thank this.
