Is this Freightliner a good deal?
Discussion in 'Ask An Owner Operator' started by PowerPullin, Mar 10, 2015.
  1. PowerPullin
    PowerPullin Light Load Member
    72
    6
    Dec 20, 2014
    PA
    I found a what I think might be a good deal on a used truck. Its a 2001 freightliner columbia, C15 cat 6nz, 70 in condo, 10 speed, 1m miles. He is asking $10,000. What do you guys think? Don't know any history on the truck so I'm a little nervous. Thanks.
  3. popcorn169
    popcorn169 Road Train Member
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    If you are looking at this truck and do not know any history then I would get a oil sample and have it analyzed. I would also take it and have a dyno done on it. If you have a local shop that you deal with I would have someone do a thorough inspection done also. Also have the charge air cooler tested to see if it needs replaced.
    I do not know what that year truck is worth but a lot of trucks with a million plus miles have about a few more years left before they need rebuilt. With that being said there will be some small items that will need to be repaired or replaced. That is just the fun part of owning a truck.
    I know the 6nz cat is a good engine.
    TURKER Thanks this.
  4. 30-aught-6
    30-aught-6 Light Load Member
    155
    128
    Dec 16, 2014
    Go to rigdig.com and pay $30 bucks and enter the vin number in, its a car fax for big trucks if any thing majorly went wrong with the previous owners it will show,if its been REPORTED OF COURSE,dont lay all your eggs in one basket,ask for maintenence paperwork,a good O/O or company will have records on hand,get a oil sample,check and smell rear end oil for burn smell,check coolant,check brakes,drums,slack adjusters,tires for wear,could indicate wheel alignment needed,or bad king pin,check oil for blowby,me personally i like detroits 60,easier to work on and parts arent as high,check truckpaper and see what that model with mileage is selling for,compare and contrast,does ac/heat work? If not whats wrong and why installing a new ac system can easily run $5 to $7000,how much rubber on tires?what do you plan to do with it,what are the rears? How well was it taken care of,normally unless its been well taken care of YOU WILL HAVE TO PUT SOME MONEY IT,n nothing is wrong with putting money in it,JUST NOT TOO MUCH:biggrin_25521:
    Dont be in a rush to buy it,sleep on it make sure its what you want,once you pay for it,WHATEVER IS OBVIOUS OR HIDDEN PROBLEMS IS NOW YOURS ,:biggrin_25513:
    Wish you the best:biggrin_2559:
    Switches Thanks this.
  5. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    10,000$... The depreciation on these is nuts. That being said, that seems on the low side to me.
    I admit I know nothing of the topic and usually browse these to get an idea of what is and isn't good. But I'd approach with caution and follow, to a T, what the others have said.
  6. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Ya, I agree with Vilhiem, that price is a little low. If it does have 1mil miles and no rebuild it could be a good deal if you put in about $8,000 for an inframe rebuild.
  7. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Did you mean $8000 or $18000 for an inframe on a c15?
    Clasix1055 and fortycalglock Thank this.
  8. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    No. Inframe kit is around $3,200. Rest is labor. More if you need a rebuilt head.
  9. Righand81
    Righand81 Bobtail Member
    7
    4
    Feb 28, 2015
    South arkansas
    Skate board I'd like to know where u got ur pricing for a I frame kit for c-15 cuz I'm gonna buy a few to put on the shelf for that price!
    Joetro Thanks this.
  10. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    truck is worth about $5K max,,,15 year old truck and a freightliner boat anchor at that,,
  11. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    If that 6nz is in good running condition with no issues it alone is worth more than $5000. But most older trucks like that are worth more parted out than whole.
