I want to go into car carrier and was wondering if this is a good setup?
Truck: Freightliner Business Class M2 106
Trailer: Sun County 53FT 3-4 Car Hauler
I was told that the truck get 10-12 MPG. Correct me if I'm wrong.
Since it hard to find load, a 3-4 Car Hauler should do the trick.
No point of running a 6-7 Car Hauler if half of the trailer is going be empty.
Truck GVWR: 33,000 (Front: 12K / Rear: 21K)
Trailer GVWR: 22,500
I'm a little lost on the GVWR. If the truck is 33K and the trailer is 22k. Tailer weight is 9K.
the trailer 22k - 9k = 13k.
So that mean I can only put 13k on the trailer? Let say a car weight 5k and 4 x 5k = 20k.
Won't I be over the GVWR? or does some of those weight transfer to the rear axle of the tractor?
Is this a good truck and trailer setup for a car carrier?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Pster05, Dec 30, 2011.
Page 1 of 4
Something just ain't right with that GVWR number! Why in the world would they put the axles under it to handle 34K, and put such a low GVWR? If you look on the website, even those POS tri-axle wedges have a 21K GVWR, and I've seen trailers like the one you're asking about, and they are a lot stouter than any wedge I've ever seen!
It's actually overkill for hauling just cars, those tandem axles lowboys like that are actually setup more for hauling rigged-out trucks: F450- 650, D4500- 6500, Sprinters, whatever Chevy's medium-dutys are... all the stuff to heavy or wide to fit on a standard carhauler. -
You can put more than 13000 on. When you put a load on the trailer, part of the weight is on the trailer, and part is transfered onto the truck. You can easily haul 4 cars and be legal on all the weights.
I'm thinking that truck is going to get more like 7-9 mpg. also unless you have cash to pay for them with, I would go with a more affordable set up to start.
The trailer GVWR is for a single axle Sun Country, am thinking he just grabbed a photo of one with a tandem.
You could buy 2 nice used tractors for what the Freightliner will cost you, plus, get one with a real sleeper on it. Plus, once you get some heavy vehiclews on it, that Freightliner will be underpowered.
there is a nice dodge 08 3500 with sleeper and 4 car stacker on ebay for 26k, would be a nice rig to start with..
Maybe I'm gonna go with a used tractor with a single axle. Here is a picture of the tractor I'm thinking of and want to get.
Anyone know how many mpg these get? I want a big rig but those aren't getting any good mpg at all.
Unless someone can prove to me that their are some that get good mpg.
Here a question, which rig get better mpg?
The big heavy-duty or a medium-duty rig?
Or course it depend on weather, road, etc.
But just between those two rig, which one get better mpg?
Page 1 of 4
