Just wondering if there is a way to hook up a battery charger set up? I have an inverter hooked to a mini fridge and Im tired of taking everything out of it when I go home and when I leave again turning it back on and waiting for it to cool down again. I usually go home on the weekends so I have to do this alot lol.. Any ideas?
Is there a way to hook up a battery charger so inverter doesnt drain battery?
Discussion in 'Experienced Truckers' Advice' started by sbatson, Oct 8, 2012.
Page 1 of 3
Just run an extension cord to the fridge. You were gonna run an extension cord to the battery charger anyway, right?
123456 and CondoCruiser Thank this. -
Well I have to park the truck down the road about 2 miles so thats not a option. Well I guess it could be but Im sure somebody would unplug me with 2 miles of cord. lol
I guess Im thinking something of a battery maintainer thats plugged in to inverter and is connected to batteries. I dont know if this is even able to be done, Ive just been thinking to much today.
Get something along these lines. It's a solar powered trickle charger. This is just the first one I found but a little further research into it and you should be able to pin point the size you need.
http://www.buy.com/prod/12v-solar-p...truck-boat/225147894.html?listingId=17234816325(2)+2 Thanks this. -
not possible, the inverter and battery charger will always draw more power than they replace in the batteries.
A battery maintainer connected to an inverter will not work due to the efficiency losses thru the devices. A solar charger larger than the demand of the fridge should work.
Oh I get it. You wanted to plug a charger into the inverter to charge the batteries to keep the inverter going ad infinitum. ROFLOL!
You are a genius! This is the magic formula that the green religion is looking for. When you are a billionaire can I be your friend?CondoCruiser Thanks this. -
Your best option is to do what I do - bring the fridge to the house along with the contents, and plug it in there.
It is probably built into the truck.
Page 1 of 3
