Is there a MAXIMUM air pressure setting?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Guntoter, Apr 27, 2012.
  1. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    I had an interesting conversation today about the governor on my air compressor. Everyone knows that you must have at least 60 PSI in your air system when the light/buzzer comes on.
    I have looked for an hour in FMCSA and cant find anything about the MAX amount of air you can have in the system. The closest I can find is that the air tanks must hold 500 PSI before bursting.
    Can a driver be cited for having 150 PSI on his gauge?
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Yes, in Ontario the air pressure cannot exceed 135 psi.
  4. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I would think he could be cited for having 150 in USA because 150 is usually the point that the relief valve goes off if I am not mistaken, so it could possibly be unsafe and could be interpreted as an unsafe condition.
    I usually set drivers governors at 135. Gives them a little extra air if they need it.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    There are buses in Florida that are set to 140-150 PSI for various reasons.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=571.121
    The only thing close I could find is S5.1.2.2, the tanks have to withstand the cutoff pressure for 10 minutes. Every tank according to ANSI standards should have a spec label on it. Boom! No good! :)
  7. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Thanks... Im keeping mine at 135. The next level 1 that I get I will ask DOT if there is a statute. I will let you know.
    Cetane+ Thanks this.
  8. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    All new KW AD-IS EP drier have a preset gov @ 135 psi.
  9. 58Skylane
    58Skylane Medium Load Member
    388
    276
    Mar 31, 2012
    Cody, WY
    I set mine at 130. But the #### maintenance crew keep setting it back at 120. I'm going to glue the #### cap on the governor next time.
  10. Heavyd
    7,751
    6,184
    Feb 4, 2009
    A little higher pressure does help a bit with trailers with many lift axles, but regular trucks really do not benefit from it and you just over stress your compressor.
    NadeauTrucking Thanks this.
  11. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    The truck Im talking about is a mobile home toter. I need to air the mobile home tires to at least 130 so thats the main reason.
