Is the t880 a piece of junk?
Discussion in 'Questions From New Drivers' started by ad356, May 23, 2021.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    Problems with my 2017
    Windshields crack on these trucks for no apparent reason. My boss has probably replaced a dozen windshields across the fleet, maybe 20 of the trucks are t880. My windshield cracked, I dont recall a stone striking it
    Wiring harnesses, again he's replaced a ridiculous number of harnesses that fail for no apparent reason. Right now truck 84 is out of service, the fuel and DEF gauges both go up and down even when full. When the DEF gauge reading falls to empty, the truck de-rates temporarily and goes back to full power when the reading returns. I parked the truck over the fear it's not regenerating the DPF and will eventually clog with soot.
    The HVAC system is trash. The vent doors break internally again for no apparent reason. Repair involves removal of the entire dashboard and a 12 hour job. The shop was simply manually changing the vents from vent to defrost as the season changed from fall to winter, and winter to spring.
    Hood latches are terrible I've been through 3 sets, they break in the winter.
    The paccar engines in general have a host of failures, and while I never had any engine problems with 84, other trucks have had problems.
    84 is a 2017 T880 daycab but only has 150k miles.
    Now I'm temporarily driving a 2009 t660 sleeper with a emissions delete 15 liter Cummings and 18 speed manual. It's one of the few spare manuals, I refuse to drive an autoshift, as far as I'm concerned you can set the cruise control on one of those things, bail out and run it off a cliff.
    I actually like this old t660 and dont care if I have it for a month. It pulls like a beast, total animal.
    Cant kenworth build a quality truck anymore?
    Coffey Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i would say yes. they are junk
    and no, they cannot build a good truck for the masses.
  4. ad356
    2,138
    3,179
    Mar 13, 2017
    Does the t680 have the same exact problems. It's really sad because I really do enjoy this 2009 with 1.2 million miles. I know they used to make a top quality truck
  5. 359 classic
    359 classic Bobtail Member
    17
    23
    Jan 22, 2020
    I have an ‘18 T880. They had a problem with hood straps. After I went through 4 the first winter and KW had doubled checked the hood adjustment they gave me a couple prototype straps to try. They totally looked identical but have now lasted a couple winters with no issues. In general, I would agree, the T880 is a sad replacement for the T800. It’s unfortunate. I can’t complain about the mechanical aspects of it. Had very little trouble with the drivetrain. Have a MX13 Paccar.
  6. Long FLD
    Long FLD Road Train Member
    11,344
    45,646
    Mar 4, 2015
    If the trucks continually have wiring issues then they need to look for the problem instead of just throwing parts at it. They bundle the wires too tight from the factory and it causes them to rub and chafe and they get holes in the insulation. I’d start by checking where the main wire harnesses come down from the firewall and go under the cab. It’s likely they’re bundled tight to a metal brace off the frame with minimal to no protection at all.
    I can’t speak on the T880, but I like the 579 I have. The wide cab is superior in many ways to the old narrow cab Pete’s. But the KW cabs always sealed up better so a comparison of narrow cab models between the brands isn’t fair. But seeing how Pete and KW have updated their medium duty models to use the wide cab I’d say the narrow cab will likely be phased out in the coming years sometime. Especially since KW didn’t do any interior updates to their narrow cab like Peterbilt did.
    Midwest Trucker Thanks this.
  7. AModelCat
    154,214
    I'll cry if they put that wide cab on the C500 and call it a C550 lol.
    Long FLD Thanks this.
  8. ad356
    2,138
    3,179
    Mar 13, 2017
    Not the same truck getting a wiring harness more then once, but multiple trucks needing harnesses once.
    The truck I'm typing this from is the 2009. I bet it's on its original harness even after 1.2 million miles
  9. ad356
    2,138
    3,179
    Mar 13, 2017
    We had several t800s, sadly he got rid of all of them. I've driven a t800, a far superior truck to the t880. The truck I drove was truck number 74, had a Caterpillar engine, 18 speed, and smaller sleeper. Really nice truck. The head failed on the c13 and he parted ways. I think he should of just fixed it
  10. Long FLD
    11,344
    45,646
    Mar 4, 2015
    Which reinforces what I said about wires being bundled too tight. I went thru this with my 2017 579. Had phantom problems that would come and go. Finally cut everything loose, repaired the wires that had rubbed thru, and wrapped CAC boots around the bundles wherever they were tied to metal. If a bunch of trucks are having issues then maybe try and see why they’re having issues. When gauges start jumping around or there are other issues then it’s time to start looking for the reason why they’re doing it. They probably could’ve fixed the wiring instead of putting a new harness on and saved quite a bit of money.
    And there are steps that can be taken when the truck is new before it’s even put in service. After fixing the wiring on this truck do you know what I’ll do to my new one in September before it goes to work? I’ll cut the bundles loose and wrap CAC boots around the wires every place they’re tied to metal.
    Midwest Trucker and AModelCat Thank this.
  11. AModelCat
    154,214
    When I worked at the dealers I'd always try and mitigate issues like that if they were a common thing I noticed. Problem is it takes time and it seems nobody wants to pay.
  12. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    I drove 1 KW and wasn't impressed. 2021 W900 X15 18 spd. After 10k, switches on the dash stopped working (hazard, PTO, engine brake, and dump valve switches) intermittently, the LCD screen shut off randomly and you had to shut the truck down and start it back up for it to work, the door switch corroded and shorted out all the interior cab lighting, endless rattles, and even though I'm only 6'1" I felt so crammed in there compared to the 386 Pete I drove. I'll never drive another KW if I can help it.
    AModelCat Thanks this.
