I've replaced a pre-cooler in a 2007 International 9200i because apparently it got soaked in radiator fluid (See picture1.jpg). I got one on the junk yard to replace pre-cooler#1 but for some reason it did the same thing (see picture2.jpg). (notice the radiator fluid inside the pre cooler). Is radiator fluid supposed to go into this pre-cooler? Now I'm going to replace it with a new one but I'm not sure if this will do the same thing. This pre-cooler is not cheap. Cost $1500 for a new one.
Is the problem the pre-coolor or something else?
Discussion in 'International Forum' started by gabton-tankers, Sep 23, 2014.
Your original cooler is bad, and so is the one from the junk yard. You should not see coolant with a good cooler. The coolant stains means it has failed.
I'd replace the coolant diverter valve diaphragm with that new cooler. They had a service bulletin a while back, but I can't find it now. It was restricting coolant flow to the pre-cooler and the higher temps in the cooler could cause premature failure. It was simple, 4 screws a replace the diaphragm. They should be checked when ever you replace the pre-cooler. I think the new diaphragm has a white center, but I'm not sure, I wish I could find the bulletin.
Heavyd and QUALITYTRUCK Thank this. -
I found the service bulletine, it is SEBD6867. I cannot find it online, so here's a quick summery:
C11 (S/N: KCA1-UP)
C13 (S/N: KCB1-UP)
C15 (S/N: BXS1-UP; MXS1-UP; NXS1-UP)
When replacing a precooler on the serial numbers listed above, inspect the coolant diverter valve diahragm. If the diaphragm does not have a white teflon disk, replace the diaphragm using the 319-6059 Diaphragm Kit.
It also says that if a coolant sample indicates engine oil, the diverter valve should be checked.W903B, Chickentrucker20, QUALITYTRUCK and 1 other person Thank this. -
I have a C13 cat motor and I am getting oil in the reservoir. I have already changed the oil cooler. Could this be a pre cooler issue.
