Is the C13 a bad engine?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by durallymax, Feb 18, 2012.
  1. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    Looking at a truck with a 430 C13 07 pre-dpf model 580,000 miles. Having it dynoes and oil tested. If these check out is there other things to look for? or is this an engine to stay away from? Seems some people I talk to say to run away from them, but the next person says to run away from the cummins, and the next person says the C15 has enough quirks too but sounds like it might be better. C12 isn't big enough for us.
    Just wondering if this engine is really that much worse or better than other engines for that year.
  3. JDP
    JDP Medium Load Member
    377
    404
    Sep 25, 2011
    Dubuque, IA
    I've got 12 Petes with the same EPA 07 C-13 430 HP/1650 ft/lb. No major problems to date, except some regen issues. The dealer replaced the ARD heads to an updated version which cured the issue. The motors only have 250K on them so we're getting ready to start replacing DPFs. I would definitely check how much soot load is in the DPF, they're not cheap to put new filters in.
    Our drivers love the motor, having a CDL myself, I also am impressed with the way they pull. Mileage isn't quite as good as we were use to when we had the MBE4000. Still averaging around 6.1-6.3 pulling steps and RGNs grossing 78-80K with the C-13. That is gross fuel consumption w/o APU, sensible idle time, and Espar cab heater.
  4. steelbeltsdrumming
    steelbeltsdrumming Light Load Member
    121
    61
    Jan 28, 2012
    Winona, MN
    One of the problems I remember with that motor was the actuators for the turbos had problems, sometimes severely making severe power loss. Cat may have done a recall on that I'm not sure. Definitely get a pre 2007 emissions one if you can, dont bother dealing with DPF if you dont have to.
  5. NadeauTrucking
    NadeauTrucking Light Load Member
    85
    45
    Jul 24, 2011
    Bristol, CT
    From my experience, the pre-dpf c-13 is a really good engine. good power and very little issues. early 2000's c12's were also very good in my opinion as well.
    steelbeltsdrumming Thanks this.
  6. JDP
    377
    404
    Sep 25, 2011
    Dubuque, IA
    Sorry, I didn't see that you were looking at a pre-DPF motor. One on my O/Os just spent 8K to replace both turbos and water pump on his EPA 04' C-13 Acert. I have heard that the turbos last 500-600K. He pulled them to check the shaft play just as some PM and found they need to be done. May want to check that too?
  7. JDP
    377
    404
    Sep 25, 2011
    Dubuque, IA
    The c-12 is a hell of a motor. We still have a couple 2000 FLD 120s for city use that have over 870K w/o any sort of rebuild or major motor work.
  8. durallymax
    318
    97
    Jan 30, 2011
    I will che k the shaft play thanks. Aside from that anything else?
    Sent from my Motorola Electrify using Tapatalk
  9. gerardo1961
    gerardo1961 Road Train Member
    1,737
    601
    Feb 21, 2010
    Miami
    My Columbia 07(maybe 06 engine)/,with cat c-13,500hp(mr.haney-ecmtuning)Mpg from 5,8(heavy)-8,4(very light),i'am very happy with this engine,in 250k enginerepairs,headgaskets($850 labor plus parts),1 turbo-$1100.-(rebuild with warranty)plus $280 labor,extra 1 radiator,1 starter,1 airdryer.I hope this help for you,When I buy my next truck (386)only with c-13.
  10. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    With the few I've worked one the KCB serial number engine seem to be very reliable. They respond very well to a ECM upgrade using a European Emission file 500 Hp 1750 torque
  11. jimvrg
    jimvrg Medium Load Member
    301
    82
    Jan 11, 2012
    yellville arkansas
    turbo issues for sure,
