Is pre-trip inspection book required
Discussion in 'Experienced Truckers' Advice' started by Yank the Tank, Jul 29, 2022.
  1. Yank the Tank
    Yank the Tank Bobtail Member
    45
    115
    Jun 14, 2022
    In a slip seat tank operation. Where I work they refuse to give us pre-trip books if there is a defect you don’t always know about it and it can be scary hoping everything is ok.
    If I get inspected by DOT with no pretrip book will I be nailed to the wall ??
  3. YumDinger
    YumDinger Light Load Member
    79
    154
    May 5, 2022
  4. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I’m not aware of a pre trip book but I’m not aware of a lot of thing
    I get you wanting some record but if you did the pre trip inspection before you took over then it should be good right?
    Doing that you should be aware of anything major and I assume the only thing you would t know is some weird quirk
  5. Big Road Skateboard
    5,707
    29,782
    May 2, 2021
    This is why you do a pretrip, to find possible issues. You don't need a book to do it
  6. Eddiec
    Eddiec Road Train Member
    2,193
    3,359
    Feb 2, 2015
    It is called a DVIR book....
  7. wis bang
    wis bang Road Train Member
    3,348
    3,918
    Jan 12, 2011
    Levittown, PA
    You are required during your pre-trip to review the last DVIR to insure that any defects reported by the last driver were corrected and signed off by the mechanic.
    Remember the OP said slip seat so there is no assigned units -or- your assigned unit is shared with another.
    When Chem Leaman took over driving for Liquid Carbonic we set up 33 trained drivers working 15 tractors with alternators to power the pumps on the cyro units and in the old days of 15 hour shifts we re-dispatched the tractors every 16 hours.
    Since that whole terminal was a slip seat setup, the staff was trained to collect DVIR's and re-issue copies of them to to the papers for the next guy.
    We lost a grievance when the cyro guys figured the DVIR's we gave them were a shift behind.
    Even with the new 'only write a DVIR when something is wrong rules; the next driver needs a signed off copy of a DVIR if the last guy reported something. Your company should have one from the last time anyone wrote up any truck on file for 90 days.
  8. Yank the Tank
    45
    115
    Jun 14, 2022
    That’s what I was thinking. Thanks.
    May need to make a call to DOT. Not letting these sloppy managers put us in a bad position.
  9. YumDinger
    79
    154
    May 5, 2022
    Something doesn't add up here.
  10. lester
    2,915
    7,846
    Jan 2, 2012
    NW, Iowa
    So do an inspection yourself?
  11. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    After you make that ph call
    You probably wanta start writing out your resume so it's ready when you start filling out job applications
    Oh yeah ... don't forget to tell at your job interviews that you called the DOT on your former employer..That's guaranteed to get ya some bonus points at the interview
    jcatel and Oxbow Thank this.
