Is Pre-Trip Documentation Required by DOT ?
Discussion in 'Questions From New Drivers' started by SilverBulletBand, Apr 19, 2021.
  1. SilverBulletBand
    SilverBulletBand Light Load Member
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    If so, can someone show a link to the Regulation please ?
  3. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    @ZVar
    From what I can tell, you're only required to do post-trip paperwork. In the morning, you're required to do an inspection, and check the last post-trip, but you only have to do paperwork if you find an issue.
    Electronic Code of Federal Regulations (eCFR)
    SilverBulletBand, ZVar and not4hire Thank this.
  4. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    To the best of my knowledge, this is what the regs are.
    Edited to remove the information already posted!
  5. Moose1958
    15,090
    33,171
    Dec 17, 2010
    I was speaking to a DOT officer I know about pre/post-trip inspections. He was laughing a bit about this subject. He said and I agree that stoves don't come with a sign that says don't touch the hot burner. But, everybody knows if you touch a hot burner you are going to get burned. The same can be said for actually getting out of your truck and inspecting it.
  6. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    When I was in wireline, we pencil-whipped everything to begin with. When they told us we didn't need to document the pre-trip unless we found an issue, us hands interpreted that as pre and post. So basically we stopped doing paperwork all together overnight.
    Hey OP, are you asking out of curiosity? Or is this to settle an argument with your company or a cop?
  7. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    I think you may getting written up by the companies safety if you dont log it
    SilverBulletBand Thanks this.
  8. veterandriver46
    veterandriver46 Bobtail Member
    Apr 19, 2021
    Hello, now your hearing from a 2nd gen veteran driver with 20 years experience about your question. yes you need a paper copy of the inspection report if your using paper logs it's normally on the back of the log sheet. if you are using an eld then no if the system has the pre/post trip inspection form is installed in it. normally it's under the on duty not driving tab. if it's not in the eld then you must fill out an inspection form for both pre and post trip inspection. A key rule to burn into your brain. rule #1 cyb =cover your butt! rule #2 read rule #1 again.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    A post-trip report is only required if a defect is discovered or reported as per §396.11(a)(2)(i) (as posted above).
    A driver doing a pre-trip would only be required to acknowledge a post-trip report if one had been previously prepared as noted above. Otherwise, no pre-trip report is required as per §396.13(a).
  10. Frank Speak
    Frank Speak Road Train Member
    4,478
    13,665
    May 3, 2016
    You have to log a pre-trip, but you no longer have to fill out a report unless you find something wrong that will prohibit the safe operation of the vehicle. They changed the reg requiring one whether you found anything or not 3 or 4 years ago.
  11. Rideandrepair
    17,202
    55,796
    Aug 8, 2015
    There’s an exception, If only running one Truck, One Trailer. both Owned and Driven by the same. It doesn’t need to be noted. I always note it myself. Not going to argue with the DOT.
