Is Part time driving possible?
Discussion in 'Questions From New Drivers' started by Bigtruckdrver504, Dec 12, 2021.
  1. Bigtruckdrver504
    Bigtruckdrver504 Bobtail Member
    28
    17
    Dec 12, 2021
    New Orleans
    Hello All.
    I am in the process of getting a class A CDL. I should have it in about 3 weeks. I already have my twic & dot med card. I plan to attain the doubles/triples,hazmat, and tanker endorsements.
    I currently have a Class D license and have drove non CDL trucks in the past.. I have no semi experience.
    My current availability is after 4 pm on weekdays and anytime sat & sun. Is it possible to find work part time?
    austinmike Thanks this.
  3. N00bLaLoosh
    N00bLaLoosh Road Train Member
    1,027
    8,024
    May 13, 2021
    Novi, MI
    Are you working a full-time job too?
  4. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    Yea. mon-fri 8am-4pm (35 hrs a week)
  5. tscottme
    tscottme Road Train Member
    Apply with the companies that supply temporary truck drivers to trucking companies with a shortage. These companies are sometimes called Driver Leasing Services and they go by many different names. You tell them when you are available.
    LoneRanger Thanks this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    If your availability is after 4 because of other jobs then it's very unlikely. Those other jobs count on your Hours of Service clocks. Otherwise you can look for a local temp agency and see what they say.
    95% of business fail, and that's working 70-100 hours a week. No one will hire you unless you actually make money for the company, which means the truck has to be in use.
  7. Chinatown
    Chinatown Road Train Member
    73,230
    164,412
    Aug 28, 2011
    Henderson, NV & Orient
    U-Haul
    6210 Chef Menteur Highway, New Orleans, LA
    $15 - $20 an hour
    CDL-A driver
    Part Time Position- will work around your current schedule.
    • Operate a flatbed truck
    • Operate an 8000lb pound propane forklift or a truck-mounted forklift
    • Load and unload storage containers for delivery
    • Transport storage containers to and from specified destinations, e.g. customers’ homes and local businesses
    Capacity, austinmike and BennysPennys Thank this.
  8. N00bLaLoosh
    1,027
    8,024
    May 13, 2021
    Novi, MI
    Shouldn't be too bad. Unless the rules have changed over the last two years you'll be limited to 25 hours on-duty per week but you're only looking for part-time anyway so should be something out there for you. Hopefully.
    EDIT: got ninja'd by Z'var
  9. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Ok, so you must get time for a 34 hour reset, plus 10 hours before every shift,.
    So you work 8a-4p at your job. That leaves Mon-Fri you can work 4p to 10p (both for the 10 hour clock and the 14 hour clock) and Saturday. Sunday you will have to take off because of hours of service will force you to a reset. Actually likely you won't be able to work much on Saturday because of the 70 hour clock.
    Hopefully you can see why companies don't want to deal with part time workers.....
  10. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    BennysPennys Thanks this.
  11. Bigtruckdrver504
    28
    17
    Dec 12, 2021
    New Orleans
    Yup. I had applied today to it, but it was from a different job board that didn't have some of the info that's on the one you posted. Thanks
    austinmike, BennysPennys and Chinatown Thank this.
