Is it safe enough to open coolant reservoir when empty
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by P60608, Apr 13, 2022.
  1. P60608
    P60608 Bobtail Member
    6
    Dec 22, 2021
  3. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Its never good to open a coolant reservoir when it is hot. You should be ok if the reservoir is empty, wear gloves and crack the cap first don't just take it off. Also a good idea to wear eye protection.
    WildTiger1990, P60608, Hatt91 and 2 others Thank this.
  4. W923
    W923 Road Train Member
    1,296
    3,924
    Feb 28, 2022
    The steam is as much a problem as the water is and it’s likely to have steam if it’s low and hot.
    A glove and some caution is always a good idea
    P60608 and Oxbow Thank this.
  5. Hatt91
    Hatt91 Light Load Member
    153
    350
    May 18, 2018
    Agreed. Crack the cap to relieve any pressure, then when the pressure is equalized you can remove the cap.
    mitrucker and P60608 Thank this.
  6. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    Trick I learned many many years ago about radiator caps and pressure. Find a rubber hose connected to it. Preferably one of the bigger ones. Squeeze the hose to see if there's any pressure in the system. If so, DO NOT open the cap. If you can easily squeeze the hose, be careful for the potential for pressure. But, you're probably OK to open it. Typically, it's a screw on cap, Just be slow and if you start to hear any hiss, close it back up.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Or leave it open just a tiny bit to let the pressure bleed off. Of course that tends to mess with the coolant level so it's still better to wait until it's cool.
    Bean Jr. Thanks this.
  8. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    Um, why is it empty? Trouble a brewin',,,even those plastic reservoirs have pressure, but I'd see where the coolant is going,,:crybaby:again and again and again, you get the idea, this is another of those questions that's pretty basic, and again, I don't blame this person, but a lack of mechanical knowledge can be dangerous, even deadly. The fact that someone doesn't think a coolant container when hot may or may not be dangerous,,,I know, I know, they asked, but it's still a mechanical machine that requires at least a shred of knowledge. May as well ask in the same question, "where's the nearest Urgent Care?
    baha, npok and Johnny18 Thank this.
